Strange issue with caliper pistons retracting during turn
Hi all,
it's the month for me to manage issue with my brake system
to sum up, I upgrade my 911 3.0 SC brake with the front and the rear Boxster 2.5 calipers plus the turbo Master cylinder (23mm)
no issue with the brake booster
when I drive the car in mountain I notice after hard turn an increase for the pedal travel to brake (several cm) so it's not a good feeling you can imagine.
I find a way to reproduce the issue
last brake pedal pressed give a firm feeling
I do 10 left / right fast steering move (like to warm up the tyres)
I press the brake pedal and the travel increase a lot
I press again (1 or 2 times) and it's coming back with a firm feeling
no play with the wheel bearings (changed)
caliper rebuild
new master cylinder Turbo model
you cannot imagine how many times we do the bleeding for the brake system
same situation with different brake pads
I start to consider it's an issue with the caliper repair kit and the seal (bad quality)
I would appreciate a tips / idea this issue make myself and the garage shop to become crazy
thanks a lot
Old 03-13-2024, 07:06 AM
Bad master cylinder ?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-13-2024, 08:01 AM
You mean not capable to keep the residual pressure perhaps ?
It s a new master cylinder from Porsche 2020 part
Old 03-13-2024, 09:53 AM
It's a 914 ...
stownsen914's Avatar
Just confirming .. with the new wheel bearings, you are sure there isn't any play? I ask because a worn strut spindle could produce symptoms similar to worn or misadjusted wheel bearings.
Old 03-13-2024, 12:25 PM
It's a 914 ...
Speaking of wheel bearings, you checked your rears too for play, loose stub axle nut, etc?
Old 03-13-2024, 12:27 PM
Could it be anything to do with the routing of the flexi brake line which, if incorrect, could put some kind of undue pressure on the line and kink it or some other issue? Might be worth a look.
Old 03-13-2024, 12:54 PM
We triple checked for the front and rear bearing
No play
I will check for the line good idea
Perhaps the change direction can interact with …
Old 03-13-2024, 03:22 PM
Pull one pad, depress pedal to move the piston out a bit, pry the piston back so the pad just slips in and no more. Do the rest. Might work.
206 637 4071
Old 03-13-2024, 06:06 PM
Alan L's Avatar
Sounds like float/runout in the rotors?
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 03-14-2024, 12:14 AM
It's a 914 ...
I"ve had a brake line go bad on a non-Porsche, and it gave really strange braking symptoms. I don't know of a way to check them for failure though, aside from just replacing. If they're old (or if very recently replaced, coincident with your current issue, perhaps one is defective?), maybe consider replacing.
Old 03-14-2024, 06:13 AM
I would replace the front brake lines flexi portion with stainless steel . . maybe if its old rubber it is expanding under pressure.
Old 03-14-2024, 06:53 AM
Alan
Are they floating rotors?
Old 03-14-2024, 07:57 AM
Bill Verburg's Avatar
a common issue w/ caliper adaptors is flex. They are less than ideal in terms of rigidity.
Bill Verburg
Old 03-14-2024, 07:59 AM
Never knew that ...
Old 03-14-2024, 08:29 AM
theiceman's Avatar
how recently did you put these calipers in and were they rebuilt calipers.
I have had this issue quite a few times on new/ rebuilt calipers and i would consider it normal. John eluded to it somewhat
when you let off the brakes the rubber seal kit is pulling the piston back in to its resting position back into the caliper. Takes a while for the piston to realize its supposed to be out there and the rubber seal kit to lose its old memory and stop trying to pull it back . typically i've seen it take up to a week of driving, then it seems to be fine.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 03-14-2024, 09:16 AM
3rd_gear_Ted's Avatar
Mr. Bill,
Your opinion please to dig deeper.
Is it the change from radial to axial mounting of the caliper or the adapter design or ???
1980 911 - Metzger 3.6L
2016 Cayman S
Old 03-14-2024, 09:28 AM
Originally Posted by 3rd_gear_Ted View Post
Mr. Bill,
The fact that your adding material and fasteners in between the caliper and the hub especially aluminum is enough to add flex to the equation.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 03-14-2024, 09:47 AM
Hi
So stainless line
Solid rotor
Caliper rebuild and done 15000 miles since
I have this issue since several year
Not a problem in normal driving condition
Because I cannot feel a big change with the pedal
But with hard drive and mountain roads
It s boring and dangerous
To think
This time the pedal is firm
Or spongy …
Old 03-14-2024, 12:10 PM
The pedal gets spongy when the brake fluid boils and vaporizes due to dragging brakes.
206 637 4071
Old 03-14-2024, 03:11 PM
Mr. Bill,
No, it's just flex, the old S calipers were notorious for it.
Bill Verburg
Old 03-14-2024, 04:23 PM
