Why is this leaking?
This is a CV boot on the gearbox side of a 356. It is leaking since it was newly replaced. Can someone enlighten me on why?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-16-2024, 09:44 AM
Is the seam at 45° from vertical or vertical? Can't tell from the pic.
206 637 4071
Old 03-16-2024, 11:47 AM
It's horizontal . is that the problem?
Old 03-16-2024, 12:02 PM
Could be. Some sealer at the end gaps helps, too.
206 637 4071
Old 03-16-2024, 01:44 PM
proporsche's Avatar
in the past i have experienced if it was way too tight it would leak-at the bolts and nuts...Also i would but wider clamp..is that an aftermarket rubber?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-16-2024, 02:23 PM
Ivan
They don't have original rubber anymore.
Old 03-16-2024, 02:54 PM
Been there, John’s advise is spot on, mine still would weep on the wheel side. Ended up sanding a smooth section on the tube and sealing. Sorry do not remember the sealant I used but no leaks since.
Old 03-16-2024, 03:17 PM
