I'm good with tools.
I always enjoy your updates Jon.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 02 996 4S (owned since new - heavily optioned) |
(man/dude)
I enjoy sharing them!
Getting back in the swing of things, have a few custom orders to fill... Kevlar is a bit of a nuisance to work with and tough to cut. Both in its cloth form and once it's cured into a part. ![]() I've been through a few sets of these shears... ![]() These are the carbon/kevlar cloth parts required for a single skid plate. ![]() While I'm cutting I decided to prepare enough materials for 2 more (which results in little to no waste which is nice). ![]() Time to warm up the oven! ![]() ![]()
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Hey john, when I made a carbon airbox for my bike, I used the roller cutter on a cutting mat. Seemed to work better than shears.
(man/dude)
It's the Kevlar that's the problem, it's whole different ball game. Shears only, and special ones with serrations, at that - otherwise it just slides out of the jaws!
(man/dude)
Tech tidbit for the tech forum: carbon cloth, although easy to cut, is still edge bound with Kevlar thread which is impossible to cut with the roller! So you still need to snip that when you cross an edge:
![]() Cutting and "laying up" the dry cloth takes a lot of time. So does the vacuum bagging, especially when you can't find the leak and have to start over from scratch. It's worth it in the end, this beauty is done in the oven and will be shipping out today! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
(man/dude)
I often start my day drinking coffee, walking the dog, and de-cluttering my inbox (not all at the same time!).
I've signed up for the potentially ruinous notifications of the tastiest BaT auctions. Occasionally sometime comes up that's so incredible that I just have to share... ![]() https://bringatrailer.com/listing/1968-porsche-911s-13/ How's that for motivation?!
Jon, thank you for this BAT find. I am currently traveling and would have likely missed this. I am now following and will bid on it. I don’t need it and am not sure how the importing all works but wow.
(man/dude)
Having sold two cars into the states, I can tell you importing is not that hard. The toughest part is paying for it (and it's not even that expensive, from a percentage standpoint!). Importing that car to the states would add a lot of value to it IMO. There might be some question as to the authenticity of the VIN stamping in the trunk? To my eyes it's not original, and interesting to see how that plays out and how it affects the value.
Motivated
Paul 83 SC The Herring |
Back at it
Jonny,
Good to see you’re back at it. Who says you can’t make a silk purse out of a sow’s ear. Maybe a little Ozempic in the fuel tank might help with the weight.😂 Seriously, looking forward to following your progress Mark
Mark 1971 911E targa Priors: 1955 Speedster, 74 911 coupe, 69 911T coupe, 74 911 slant nose w/928 lights, 03 911 Turbo |
Full Send Society
Those rear flares are giving me ideas... bad, bad, bad, delightful ideas... Shame on you Jonny
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
(man/dude)
Wow - it's been a minute! I've been popping my head in here on and off, but mostly to answer PMs from people inquiring about parts.
On a personal level, there have been numerous challenges, distractions, and quite difficult times as of late - also some busy times with fixing daily drivers and doing actual paying work! The time I saved by not posting to this thread has been put to use, though! I FINALLY got a set of molds I was happy with for the sunroof. I didn't end up being impressed with the surface of the epoxy tooling gelcoat and fiberglass epoxy construction for the grey epoxy mold from last fall. There was simply too much waviness in the surface of the parts that I made from this mold, for me to sell them to paying customers. There was a lot of wasted hours, wasted material, and swearing (largely at myself, but not exclusively) to get from that point to a final mold, with a surface that's acceptable (everyone knows I'm a sucker for a good reflection!): ![]() Ultimately I ended up here, and yes, I am happy!: ![]() There were numerous difficulties and outright failures along the way and ultimately I am now making the sunroofs from the 6TH!!! ![]() ![]() ![]() I also started working on the pattern for a decklid. Generally this involves a lot of tape and signboard and glue and chewing gum: ![]() ![]() Ultimately you end up here. It also does require that you fix and fettle and sand to perfection the pattern part you want to replicate: ![]()
Nicely executed. Can't wait to see final part.
That’s a lovely looking rear deck lid, Jonny.
Curious if your learnings on sunroof are transferable to other parts of the program? Said differently, have you broken the back of it or more grafting ahead? Either way, thanks for persisting |
(man/dude)
Getting there! (See below...)
(man/dude)
Case in point, that decklid mold. I continued on with the process I've now honed to what I thought was a fine point: ![]() ![]() ![]() ![]() ![]() I ended up with a perfectly wonderful mold which in 99.9% of cases would, I'm sure, be... GOOD ENOUGH ![]() ![]() Anyone who's been following my display of self torture for enough years will know I don't do "good enough". It turns out "low shrinkage" mold making resin is not "NO shrinkage". I mean it's really, really, really close to zero, but not zero. Which means that parts produced from this mold would be really, really close to the size of the original decklid, BUT... To paraphrase Peewee Herman, there's always a big but... 2 or 3mm across the full width of a decklid doesn't sound like much, but translate that into panel gaps and you've got 1-1.5mm of panel gap growth which is not gonna fly. At least I've gotten to the point where I'm actually pleasantly surprised when something goes right, as opposed to really getting upset when things don't! There's more to this story but I need to get to work, so it'll have to wait till next time.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 Last edited by Jonny042; 03-12-2025 at 05:42 AM.. |
I'm thinking how I beat on myself over perfection, yet it's unobtainable. 1.5 mm in my world would fly all day long. You continue to inspire.
Uncertifiable!!!
Jonny, I envy your workmanship and persistence to achieve perfection. It certainly inspires many of us on this board to just strive for the next level and still stay sane!
Just mulling over my next project after I finish Sweet Transplant…..maybe an all carbon-a-Jonny. LOL Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Wow!!!!
I need a raise in my allowance.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
