Banned
The last build is the stuff of legends!
(man/dude)
Thanks! I've got lots of interesting plans for this next one, I'm hoping to speed the development of the carbon parts a bit so I can share something that's of more interest, especially if pondering the minutia of resin shrinkage isn't as fascinating as watching paint dry or grass growing!
Back to the minutia: Like I mentioned I took quite a while to come to terms with this and even did some testing. I made a mold of a steel ruler to see what would happen: ![]() And sure enough, once the ruler "popped" from the mold, it would no longer go back in the mold: ![]() This mold was made under the ideal conditions for low shrinkage, with a relatively slow cure under a tightly controlled 20 deg C temperature. The shrinkage isn't massive, but it also isn't nothing. Over the 12" ruler it's somewhere in the neighborhood of .5mm. Still enough to allow the dimension of the decklid mold to end up with a dimension 1.5mm "off" of the pattern part. I have not yet tested the shrinkage of the composite carbon/resin matrix when cured, but I suspect it will be very slight (if again nearly undetectable). With all that, I decided to very slightly increase the size of the pattern part. More on that soon!
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Banned
Yeah right.
(man/dude)
So, to recap - if you take a mold from a part and the mold shrinks as it cures, the mold will be smaller than the pattern part (the one you're trying to copy).
If the resin you make the part from shrinks, the part you make from the already smaller mold will be even smaller. Both of these factors are very, very, very small, but if you're trying to build a car and want to maintain tight, even, parallel gaps, even a single mm is going to wreak havoc. So I decided it would be easier for me to add a small amount to the pattern part, rather than having to add dimensionally to the carbon part which isn't really easy to do. Then the parts can be fit to the car. Singer does this (at least with their "classic" model) - the carbon body panels are made with intentionally small gaps which are then fit by hand to the individual chassis. I did a bit of testing and figured out a way to add a 1mm strip to the edge of the decklid on three sides: ![]() And went through the surface coat spraying and block sanding process again, and again, until it was perfect...again! ![]() ![]() And finally made a mold, again! ![]() ![]() ![]() ![]()
Looking great, Jon!!
scumbag
IDK what's in the water up there, but I could use some.
Jonny, your determination and attention to detail is unmatched.
http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html https://forums.pelicanparts.com/porsche-cars-sale/1180319-fs-1979-widebody-lightweight-coupe-hotrod.html AchtungKraft #009 - IG: @doktor_b |
(man/dude)
For much of the year, we need to make water. As always, thanks for the compliment! I sure hope this mold lives up to the promise!
(man/dude)
Some actual project content
I was (a few years ago?) truckin' along with the motor build, most of which involves rounding up the necessary parts and cleaning. I don't care for cleaning parts but I do enjoy looking for parts... as I get back into the project I'm hoping to be able to share something other than me pulling my hair out trying to make carbon parts!
These showed up from the other side of the Atlantic (if it's even still called that ![]() Quote:
![]() As you can see I've done my homework, but homework was never my strong point... still, I'm going to follow the science and run these with confidence. Many thanks to Brookieslayer for the help with the hardness testing!
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 Last edited by Jonny042; 03-15-2025 at 05:21 AM.. |
I can't help but admire the attention to detail. simply amazing
scumbag
OOOOOHHHHHHH.
I like that.
I'm good with tools.
Very very nice stuff.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 02 996 4S (owned since new - heavily optioned) |
(man/dude)
Goofing off today
Messing around when I should be working. What good is a prototype if you aren't testing it?
![]() ![]() Of course there's a video. What my methods lack in sophistication, they make up for in relatability(I hope!): https://www.youtube.com/shorts/he94OwHGVIc ![]()
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 Last edited by Jonny042; 03-18-2025 at 02:58 PM.. |
That’s impressive, Jonny !!
Nice work. |
(man/dude)
Sorry to bore with more sunroof stuff, but it's all I've got today! This one goes out to Cali tomorrow or the next day.
I've been trimming reinforcement from the layup in some places and adding it back in to where it can be used to strengthen and stiffen the part. I've managed to keep the weight down as I do this. I would like to trim an ounce off, though! ![]() I'm also trying to get better and faster at the construction but the sunroof involves a lot of cutting, trimming to fit the factory hardware, and making of holes in various shapes and sizes: ![]() ![]() I'm really pumped about the quality of the latest (hopefully the last!) mold. The surface of it it great. It's not so much the surface finish it's the lack of waves or ripples in the surface. This is bare carbon straight from the mold, no sanding, no clear coat! ![]() ![]() Proudly made in The Great White North and comes with all necessary hardware. The graffiti is just silver sharpie and washes right off with wax and grease remover. ![]()
Simply beautiful.
I would sign that stuff too.... well done Jon.
Uncertifiable!!!
Jonny, that is truly outstanding work. Beautiful result.
BTW, today I’m installing your carbon mini duck to Alberto. Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 03-21-2025 at 05:25 AM.. |
(man/dude)
Covering the rear
Well that went well...
![]() I'm continuing to strive to make parts that are incredible in every measure: beautiful, light, strong, and most importantly, something that I would put on my own car. I don't mind saying that this decklid is all of those things. I literally laughed out loud when I popped it out of the mold and I saw how great it looked and how light, stiff, and strong it is. ![]() This is a rough weighing of both pieces without hardware and adhesive. I do have a target weight that is a tiny bit lower than this, but I'm confident I will get the necessary grams shaved off in time. It's possible that I overshot the "strength" goalpost... (keep reading ![]() ![]() Did I mention strong? It passes the jackass test ![]() ![]() ![]() The test setup. You can see the marks on the inside of the decklid skin where the blocks bore my fairly considerable downforce: ![]()
so awesome!!
Uncertifiable!!!
Beyond impressive, Jon.
Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
