Trans output flange question
We have a trans with 110 mm fine spline flanges-would like to change to 100 mm. What is the best way to do this?
Old 03-29-2024, 07:52 AM
gearhead
Buy a couple of SC flanges, sell your 110mm ones.
Step 3: profit
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-29-2024, 08:33 AM
What Matt says - quite rare, and many turbo or 930 transplant guys with a 915 would take your arm off at the shoulder for a chance at those. Maybe the 3.6 transplant guys as well.
Or just remove the hub stub axles and use 3.2 G50 axles if your power output makes that worthwhile or you get tired of backed-off/broken M8 bolts.
'77 S with '78 930 power and a few other things.
Old 03-29-2024, 09:16 AM
76-77 Turbo had 2 different 110mm drive flanges. Open diff flanges are short and have limited application. LSD flanges are interchangeable in most fine spline diffs. By 78 fine spline drive flanges we’re the same length, just 100 & 110mm fitment.
Old 03-29-2024, 09:50 AM
It's a 914 ...
stownsen914's Avatar
Coarse spline or fine spline? Advice is similar either way, only difference is where you get the 100 mm ones from. SC / early 3.2 Carrera for fine, mid 70s 911 for coarse.
Old 03-29-2024, 09:59 AM
Thanks all for the education. The trans is a later lsd unit, so it makes sense that it would be a fine spline. So I need 2 fine spline 100 mm flanges. Should I specify length on my WTB?
Old 03-29-2024, 01:52 PM
And a final question: what would be a fair pelican to pelican price for the 110/fine flanges?
Old 03-29-2024, 05:02 PM
Bump up
would like to know a fair Pelican to Pelican sell price for a pair of 110 mm fine spline flanges
Old 03-31-2024, 05:27 AM
gearhead
California Motorsports sell new ones for $1100. A decent price for pair of used ones is $700-800.
If you’re still looking for a pair of 100mm, I might have some. I’d want $250 shipped for a pair.
1974 914 Bumble Bee
2009 Outback XT
Old 03-31-2024, 06:09 AM
Thank you Matt-please let me know if you do have a set of 100 mm
Old 03-31-2024, 06:29 AM
