Shift coupler bushing issues / 3rd set
This is now the third set of “genuine porsche” bushings I have ordered where the hole is oval. Is there a bad run of bushings or am I missing something? I order some aftermarket junk and they come in perfectly round and tight
Instagram: @TuitTech
Old 04-25-2024, 08:58 AM
They're all oval. Parts Klassic sells the round hole ones, if they're in stock. Late 914s used the round hole. FVD probably has them.
206 637 4071
Old 04-25-2024, 09:25 AM
I’m pretty sure they are oval so that a certain amount of NVH doesn’t get through the linkage and into the cabin. I fitted a Stomski coupler a couple of years ago and get all sorts of noise coming through now. It’s really noticeable on road trips so I am going back to the original design.
Old 04-25-2024, 09:32 AM
I went with brass bushings for the shift coupler. Much more precise than stock, but no extra noise.
https://www.pelicanparts.com/More_Info/RENTR18.htm?pn=REN-TR18&bc=c&q=brass%20shift
Old 04-25-2024, 09:42 AM
Still here
pmax's Avatar
That fit looks way worse than normal even for these oval bushings.
Old 04-25-2024, 10:26 AM
I can’t tell you how many of these couplers I have done over the years and this is the first I’m seeing this. I have never seen a oval or gap like this
Old 04-25-2024, 10:31 AM
Still here
pmax's Avatar
As always, what JW said.
The factory bushings has always been like that.
Here's a set I had for years ...
Old 04-25-2024, 01:16 PM
dtwa's Avatar
I put these round hole, delrin bushings in my 85 last year. A little more compliant than brass. No slack, but no noticeable NVH either. Very happy with them. —Dave
https://www.rauchandspiegel.com/product/shift-coupler-bushing-delrin-round-hole/
1985 Carrera 3.2 • Prussian Blue Metallic
Old 04-25-2024, 02:13 PM
MBAtarga's Avatar
I learned something today.
NVH stands for Noise, Vibration, Harshness
I had no clue what you guys were referring to above.
Mark
'83 SC Targa - since 5/5/2001
Old 04-25-2024, 03:03 PM
Me Too…………
Thanks for deciphering the NVH acronym. I had no idea what they stood for until you posted.
Tony
Old 04-25-2024, 04:12 PM
Curious if it is corrected by installing it in the coupler…
Old 04-25-2024, 04:18 PM
I tried there was no difference. I really have never noticed a gap/play like this in anyone I’ve done before. I would consider this excessive. I’m not expecting push tight fit, but this seems crazy
Old 04-25-2024, 04:25 PM
PCA Member since 1988
When you compress that bushing into the yoke, it will tighten up.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-25-2024, 05:00 PM
As everyone has said, factory is sloppy, aftermarket tight.
Old 04-25-2024, 08:22 PM
Schulisco's Avatar
Jim, I do not get what's the matter with the bushings? Why do you replace them? Shifting problems?
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 04-26-2024, 02:42 AM
proporsche's Avatar
yup the bushing will become rounder once it installed
Just for comparison.here is an original factory and it is owal....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-26-2024, 02:55 PM
I took the aftermarket "round" one and oval'd it out just very slightly, figured Porsche had a reason. It shifts fine.
Phil
81 SC.
930/16 (us model)
Old 04-26-2024, 03:49 PM
Getting ready to do the Shift Coupler, and Shift bushings. Does anyone know the pro/con of the following bushings for the Coupler:
Brass, Delrin, Powerflex, or OE/OEM?
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 09-22-2024, 10:01 AM
The 9 Store
Even better, switch to the Stompski coupler.
All used parts sold as is.
Old 09-22-2024, 12:32 PM
