911SC '82
Is it normal some gas pedal play and click noise?
As I am approaching my 5 months with my 911SC
my brain is getting used to the normal sounds but still uncertain what's "normal" for a 42-year-old car or not.
I just noticed the gas pedal has some travel play that doesn't affect the speed when I'm driving, and to be clear it works well as it should...but during a "silent" moment coming home, I noticed this clicking noise when I press the pedal, and it seems to come from the box where the shift coupler is (or maybe come underneath that)
the travel it seems to be barely 1 inch... that's why I kinda never noticed before or took for granted that is part of old car problems
here is the video/audio
https://youtube.com/shorts/wpAP1sbk_TI
is it normal? or does my cable need to be adjusted, or tightened somewhere?
Old 04-29-2024, 11:30 AM
Could be the throttle rod bell crank bushings have worn/failed/broken. There are nylon and aged and brittle causing some wobble as it connects to the rod. Also there 3 nylon bushings also old and brittle along the tunnel that if missing it could cause the rod to slap and wobble around.
I had the throttle stuck at highway speed due to the nylon bell crank bushings broken.
Remove the pedal floor board and examine, you’ll need to remove shifter and handbrake lever to see if the throttle rod bushes are in bits and pieces. .
Old 04-29-2024, 11:51 AM
With my 85 Carrera there is zero play in the throttle. If I just touch the pedal, the RPMs go up. Of course there is a pedal stop, so it goes only so far down to wide open. Have someone else operate the pedal, and take off the air filter and look at the butterfly on the air intake. Whit the engine not running have them slowly press the pedal and see if the throttle is opening all the way, or has slack.
Old 04-29-2024, 11:55 AM
I highly suspect the throttle bellcrank bushings at the base of the throttle pedal assembly, as EC900 references. Like EC I had my throttle stick at wide open throttle due to these bushings failing. I managed to change them out mid road trip without removing any of the shifter components, but if it is any of the bushings inside the tunnel that will probably be a different story.
Old 04-29-2024, 02:39 PM
PCA Member since 1988
Inspect and replace the throttle bellcrank and rod bushings. If they are original, they have deteriorated to the point where they are brittle and falling apart. Unfortunately, this will involve a fair amount of "while you're in there," because the bushings inside the tunnel, including the shift rod bushings are also in the same condition. It will save time to do them all at once.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-29-2024, 04:50 PM
911SC '82
thanks, do you guys mean part 91142301701?
also which tunnel are you talking about? is it the same as the shifter coupler/rod?
Old 04-30-2024, 07:58 AM
911SC '82
to clarify, I have zero issues with the engine/acceleration, the engine works great, RPM go very high (although I never tried more than 5,000rpm, and I never paid too much attention to this play.
it is more of a preventative repair in case
Old 04-30-2024, 08:01 AM
911SC '82
in hindsight... I recently replaced the fluid transmission and that throttle rod/cable was in the middle of the work... I wonder if by mistake I touched that and the nut became a tad loose and I just need to tighten it – but I don't mind replacing the part considering is 42 old
can you confirm is this to be done?
https://www.youtube.com/watch?v=ltbW66HA-hI&t=92s
Old 04-30-2024, 08:10 AM
911SC '82
I wonder if the short travel play is due to the loose nut (is it a nut?) and corresponds to the space I marked in the pic?
Old 04-30-2024, 08:13 AM
^^^ All great advice.
Pretty much zero play in my throttle linkage, any movement at all on the pedal is immediately visible on the TPS reading.
Good idea to also check the throttle stop is correctly adjusted so that the linkage doesn't get over-extended/damaged.
Regarding the "click", be careful. It could be (relatively) harmless play/wear, or the linkage/pedal could be binding on something.
It is possible for the throttle to stick wide-open because it binds against the pedal board..
'77 S with '78 930 power and a few other things.
Old 04-30-2024, 08:37 AM
Here’s a pic I posted after I had my 2 bell crank rod bushings (901.423.227.00) failed once I figured it out I also discovered the shifter bushing was equally disintegrated and remnants (circled) of the 3 throttle rod bushings (914.423.211.00) in the tunnel.
It’s not much to pull out the floorboard but tight to get new bushings in and no need to remove pedal cluster. To get at the tunnel throttle rod bushing, the shifter will have to come out and loosen the handbrake to lift it up to replace the center and rearward TR bushings. Bushings have a slit in the center and slide right on, then bend the metal retaining tab over. A shift console makes the job longer, I removed passenger seat to make install easier. Lot of extra prep work but quite easy.
BTW- I replaced my shifter bushing with the JP Novak Ultimate Shifter Bushing as well as a new ball cup.
Old 04-30-2024, 08:39 AM
Part #’s may vary by year but these are the parts in question…
Regarding your last photo, the loose nut on the lever holds it in place, I thought this would be a stationary stud, I’m not sure about that adjustment though.
Old 04-30-2024, 09:01 AM
911SC '82
the noise clearly comes from the center of the car (if you see the video) where the shift coupler panel, maybe below that, it doesn't come from the feet at all.
I'm gonna try to remove the panel when I have time, also inspect again under the car with a friend pushing the pedal
Old 04-30-2024, 11:22 AM
911SC '82
the noise is coming from the back/center
I think the pedal cluster is ok.
strangely in my PET book I can't find that rod/cable/part marked ar #18 in your image
If you have time do you mind telling me the code of part 18? just curious whats the name
Old 04-30-2024, 11:27 AM
proporsche's Avatar
19=nut
1985 911 with original 502 191 miles...808 198 km
Old 04-30-2024, 11:30 AM
911SC '82
oh ok I found it. it's part 16 (91142304300) throttle linkage on my PDF
considering the diagram and all the part, Im having hard time thinking the bushings have anything to do with this play. feels more like something happening at the linkage level or so
Old 04-30-2024, 11:48 AM
Believe me, those nylon bushings even only 2mm thick when missing can cause a whole lot of slop along the length of the rods they support - from the pedal all the way up to the throttle body.
Yes, the linkage is dependent on bushings being true and in place otherwise the linkage goes awry, even if out of center it’s going to cause adjustment issues. The rods are adjustable but hardly even come loose.
I’d bet most if not all the bushings are toast. I know it sounds too simple and taking out carpeting, center console , floorboard, shifter and handbrake isn’t fun stuff and time consuming all for a few $2 bushings.
If you can take out the shift coupler cover plate you could see if the TR bushing are intact or failed as they’ll be laying along driver side of tunnel. Might be able to take a video w/ your cell camera to inspect if you don’t have a borescope.
Old 04-30-2024, 05:33 PM
911SC '82
I can certainly start with this inspection
Old 04-30-2024, 05:38 PM
Take a look at this link, it might explain better.
Throttle Stuck and Have Question on Pedal Cluster
Old 04-30-2024, 05:42 PM
911SC '82
or maybe i'm just overthinking it...
I took a video today and the linkage seems fine, the click noise appears to come from the linkage and the engine... I will try again with the engine on... may be everything is normal.
https://www.youtube.com/watch?v=mOYbHtTziKM
Old 04-30-2024, 05:45 PM
