Removing engine tin by the fan with engine installed. Possible?
Want to remove the engine tin that runs parallel to the cooling fan (the long section below the saddle) from the engine with the engine in the car. It looks like it's possible but am not sure. Do you know if it is or isn't?
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Muffler off, then it comes out the bottom.
That's not objectionable. Thanks John
