Searching partnumber
Hi,
I'm swapping the motor of the fresh air blower of my 1980 911 SC. But there's a foam gasket which will be seperated in parts when I'm going to dismantel the blowerhouse. It's hard and crumble... Does anyone of you know the partnumber of this foam gasket (red arrow)? It's not '901-571-922-01'. And are those parts with the blue and yellow arrow also still available? ![]()
For the best wipersblades in The Netherlands and Belgium: www.nieuweruitenwissers.nl |
Someone just asked about that:
https://forums.pelicanparts.com/porsche-911-technical-forum/1163800-fresh-air-fan-part-reqd.html There are two. The one that isolates the motor is rubber. The one between the plastic motor housing and the vent duct (your part number) is foam. The number for the retaining clip is 90157192100. It is still available through most 911 part sources. Just google it.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender Last edited by fintstone; 07-05-2024 at 08:24 AM.. |
great link for that round foam....flintstone';-)
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
No problem. Only place I could find them. They also have the C-Clips under their own part number 914CCLIP and the bowden cable clips for the air box if rebuilding the vent system.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Great, thanks for this information!
Looks like it's a hot topic ![]() Unfortunately it looks like the foam part isn't available in Europe at all...
Looks like PP has the blower motor seal now:
https://www.pelicanparts.com/More_Info/N14R91157101800S.htm?pn=N14R-911-571-018-00S&bc=c&SVSVSI=9282
