Dash wire routing question.
If I wanted to run a small 16g wire from the boost gauge to the clock location, can I do that without going through the "frunk?"
Is there any communication between the upper dash and lower?
'81 924 Turbo (931) '87 944 Turbo (951)
'84 911 Turbo (930)Flachbau
'89 928 S4
'04 911 Turbo (996)
'08 Cayenne Turbo (957)
Old 07-13-2024, 12:18 PM
Yes just keep the wire away from your heat controls
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 07-14-2024, 06:02 AM
Registered Minimalist
75 911s's Avatar
Can't remember if there are any passthroughs in that general area. Basically in your photo, everything above the stereo and fresh air is the Frunk. The wires for the fresh air all route through the holes behind the ignition switch up to the frunk there. That is where I ran my wires for my AFR gauge that I replaced the clock with.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 07-14-2024, 06:20 AM
I pulled the boost gauge and don't have any access to the heater controls. Zero access to the lower dash from there. It's almost like its sealed .
'89 928 S4
'04 911 Turbo (996)
Old 07-14-2024, 06:41 AM
Thanks, I'll look to see if I can get through the ignition switch "passthrough."
'89 928 S4
'04 911 Turbo (996)
Old 07-14-2024, 06:47 AM
Been here a while
based on the console, the AC, the stereo, there should be some pass thru's into the smuggler's box and up and around, typically you'll find someone has already drilled a hole, maybe there's an amplifier under the seat, it would have a large power wire running to the battery. The factory did a pretty good job of sealing the area between the frunk, where the back of the gauges are, and the passenger compartment.
I'm sure you can sneak a small diameter wire along the fins hoses that pass from the frunk into the passenger compartment.
looking for 1972 911t motor XR584, S/N 6121622
Old 07-14-2024, 06:59 AM
Thanks, this car is, unfortunately/fortunately, original. So no "favors" done by the previous owner.
I'm sure there's something in the smugglers box but Ideally I'd prefer to not run a wire out of the lid
'89 928 S4
'04 911 Turbo (996)
Old 07-14-2024, 07:07 AM
Been here a while
no need to run thru the lid, there are plenty of wires that connect to the fuse box, relays and AC stuff that pass thru grommets around the perimeter of the lid, so you can pass thru there, and up to the gauges.
As others have stated, you'll find enough other pass thru's but most of the factory connections used a round electrical bulkhead connector, 5 to 6 pin, so you can't just pass through those holes. You will find others, but each car and each year have some changes to specifically where.
you'll do well to post some photos what what you saw when you removed the boost gauge, and what you see when you look behind that bolster along the lower dash. Also, it's a very easy task to remove the trunk carpet and divider that hides the heater/fan ducting, often there are off-white factory grommets in various places along there, also some near the brake master cylinder that would give easy access to the boost gauge area.
Old 07-14-2024, 07:12 AM
I couldn’t find any holes so I drilled a small hole for AFR gauge wiring. If you look down and too the right, through the clock hole, you can see an angle where you want the wire to come up. Then find the spot and drill from the bottom.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 07-14-2024, 04:55 PM
