'73 911 T Targa
Removing Trans Support Bracket
I need to remove the transmission support bracket in order to get to the fuel lines to replace them.
The smaller nuts in the middle (yellow arrows) came out easily enough, but the bigger ones (red arrow) aren’t budging.
I thought I’d check to make sure I’m not going down the wrong path before I break out heavier artillery.
I’m a just OK mechanic. I’m OK when things go as planned, but my skill level is such that I can get in over my head if I’m not careful.
Old 08-06-2024, 11:18 AM
Your car doesn't look too crusty at all. They are pretty tight. Just be careful of course, you can use an impact but I'd just break it free with one, then remove by hand to get a feel of what you are up against.
Old 08-06-2024, 11:30 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Agreed, just tight. Be very careful when re-installing them, the fine thread is very easy to cross thread. In by hand is the the way to go.
1986 Targa Guards Red
2021 MT09 SP
Old 08-06-2024, 11:59 AM
And on reassembly, start them by hand and be sure to not cross- thread them, or yer screwed.
206 637 4071
9dreizig's Avatar
Send a message via AIM to 9dreizig
One more note,, make sure the 4 smaller ones are loose when you hand feed the two big ones ,, just to make sure they get threaded in correctly ,, then you can tighten everything up ..
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 08-06-2024, 12:15 PM
'73 911 T Targa
Thanks a billion. I just needed a shot of courage!
I used a breaker bar extender and a little extra effort and they loosened smoothly.
Old 08-06-2024, 12:25 PM
nothing to see here
And when you put them back don’t use them to lift the transmission back into place; use a jack for that.
Old 08-06-2024, 12:43 PM
I had this problem when re-installing the bolts. One bolt fitted easily but the second bolt seemed to be going in when suddenly it became solid. I resisted the temptation to force it. I backed out the first bolt and compared the angle at which I was fitting the second bolt and it was slightly off. By following the angle of the first bolt that had fitted with no problem I was able to get the second bolt in. I now worry about what could happen next time particularly if I let someone else remove these bolts.
Roy
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 08-07-2024, 02:29 AM
Banned
Pro tip right here. If it's particularly bad you can loosen up the mounts in the whole bracket as well.
Old 08-07-2024, 05:22 AM
'73 911 T Targa
I have the trans supported by the block of wood you can just see a bit of on the left side of the photo.
Old 08-07-2024, 05:40 AM
