'73 911 T Targa
Removing Trans Support Bracket
I need to remove the transmission support bracket in order to get to the fuel lines to replace them.
The smaller nuts in the middle (yellow arrows) came out easily enough, but the bigger ones (red arrow) aren’t budging. I thought I’d check to make sure I’m not going down the wrong path before I break out heavier artillery. I’m a just OK mechanic. I’m OK when things go as planned, but my skill level is such that I can get in over my head if I’m not careful.
Your car doesn't look too crusty at all. They are pretty tight. Just be careful of course, you can use an impact but I'd just break it free with one, then remove by hand to get a feel of what you are up against.
Agreed, just tight. Be very careful when re-installing them, the fine thread is very easy to cross thread. In by hand is the the way to go.
1986 Targa Guards Red 2021 MT09 SP |
And on reassembly, start them by hand and be sure to not cross- thread them, or yer screwed.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 08-06-2024 at 12:04 PM.. |
One more note,, make sure the 4 smaller ones are loose when you hand feed the two big ones ,, just to make sure they get threaded in correctly ,, then you can tighten everything up ..
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
'73 911 T Targa
Thanks a billion. I just needed a shot of courage!
I used a breaker bar extender and a little extra effort and they loosened smoothly. |
nothing to see here
And when you put them back don’t use them to lift the transmission back into place; use a jack for that.
Roy
1959 Bristol 406 (bought in 1972; sold in 1977) 1966 Porsche 2.0 coupe (bought in 1977; sold 1981) 1978 Porsche SC coupe (bought in 1993) |
Pro tip right here. If it's particularly bad you can loosen up the mounts in the whole bracket as well.
1982 911SC |
'73 911 T Targa
I have the trans supported by the block of wood you can just see a bit of on the left side of the photo.
