Doh! Dropped spanner at the rear of my engine!
So I was trying to get to the oil pressure light switch area at the rear of my motor (3.2 Carrera motor), and dropped a 13mm spanner at the back there! Yikes!
Tried to find it with a torch and feeling around to no avail.
Any advice?! 😳
Old 11-21-2024, 01:43 AM
proporsche's Avatar
magnet
1985 911 with original 502 191 miles...808 198 km
Old 11-21-2024, 02:27 AM
Mirror on a stick. Lots of light. Magnet.
Old 11-21-2024, 02:40 AM
Targa_PB_78_SC
mike sampsel's Avatar
Tie a string on it next time so you can pull it up if you drop it.
BareRearedRookie
Old 11-21-2024, 03:10 AM
(man/dude)
Jonny042's Avatar
Or tie a string to another spanner and drop it and watch where it goes?
But seriously, it shouldn't have gone that far... I have a USB inspection camera I plug into my laptop that's really handy for these sorts of things.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 11-21-2024, 05:37 AM
Wildman Emeritus
Haven't we all done this?
Where's my 10mm socket?
All good suggestions to find and remove it. Much easier to find than a 13mm nut.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 11-21-2024, 06:04 AM
I once found a pair of pliers behind that spot left there by someone like you.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-21-2024, 06:37 AM
Meanwhile; Disconnect the battery just encase the spanner falls onto the starter motor connections!
Good luck.
Ant.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 11-21-2024, 07:57 AM
Been here a while
small hands, find someone with small hands, I suspect it's easy to put a finger or 2 on, the magnet idea is a good one, but either way, small arms will reach back there more easily.
looking for 1972 911t motor XR584, S/N 6121622
Old 11-21-2024, 08:04 AM
Originally Posted by 911TT33 View Post
So I was trying to get to the oil pressure light switch area at the rear of my motor (3.2 Carrera motor), and dropped a 13mm spanner at the back there…
My first thought is to take your cell phone, start recording video and slowly wave it around above the back of the engine, then check the video to see where the spanner fell.
You might consider unbolting the air box and removing it completely from the intake manifold, same goes for the heater blower and on the top left.
Old 11-21-2024, 08:29 AM
Mark Salvetti's Avatar
There aren't many places for it to go there. Maybe inside the engine console, under the crank pulley?
(Edit: Oops, misread the original post. I thought he was wrenching the oil pressure sending unit by the fan.)
Mark
1979 911SC Targa
Old 11-21-2024, 09:15 AM
Leave it there with the other tools... for the next owner.
Old 11-21-2024, 10:38 AM
Somewhat related story: Long ago I was working on a piece of German farm equipment that had been serviced by various other people. I dropped the engine oil drain plug and it fell into the machine frame. I had to disassemble some stuff to retrieve it and found 3 additional drain plugs in the same location...
Old 11-23-2024, 06:33 AM
