Doh! Dropped spanner at the rear of my engine!
So I was trying to get to the oil pressure light switch area at the rear of my motor (3.2 Carrera motor), and dropped a 13mm spanner at the back there! Yikes!
Tried to find it with a torch and feeling around to no avail. Any advice?! 😳 |
magnet
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Mirror on a stick. Lots of light. Magnet.
Targa_PB_78_SC
Tie a string on it next time so you can pull it up if you drop it.
BareRearedRookie |
(man/dude)
But seriously, it shouldn't have gone that far... I have a USB inspection camera I plug into my laptop that's really handy for these sorts of things.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Wildman Emeritus
Haven't we all done this?
Where's my 10mm socket? All good suggestions to find and remove it. Much easier to find than a 13mm nut.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
I once found a pair of pliers behind that spot left there by someone like you.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Meanwhile; Disconnect the battery just encase the spanner falls onto the starter motor connections!
Good luck. Ant.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
Been here a while
small hands, find someone with small hands, I suspect it's easy to put a finger or 2 on, the magnet idea is a good one, but either way, small arms will reach back there more easily.
looking for 1972 911t motor XR584, S/N 6121622 |
You might consider unbolting the air box and removing it completely from the intake manifold, same goes for the heater blower and on the top left. |
There aren't many places for it to go there. Maybe inside the engine console, under the crank pulley?
(Edit: Oops, misread the original post. I thought he was wrenching the oil pressure sending unit by the fan.) Mark
1979 911SC Targa Last edited by Mark Salvetti; 11-22-2024 at 07:29 AM.. |
Leave it there with the other tools... for the next owner.
Somewhat related story: Long ago I was working on a piece of German farm equipment that had been serviced by various other people. I dropped the engine oil drain plug and it fell into the machine frame. I had to disassemble some stuff to retrieve it and found 3 additional drain plugs in the same location...
