993 varioram Airbox or Cone Filter? which is better
Hi all,
I have a 993 varioram going into my IROC tribute. The engine did not come with an airbox so I either need to source one or put an aftermarket set up on. Does anyone have any input as to which is better? I plan on running a set of Georges headers and some kind of RSR style exhaust. Thanks, JZ
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
if you use the stock 993 console and cross bar the engine is low enough that the stock box w/ a modified cover fits you can see here where I cut away part of the cover to clear the hinges ![]() if using the 3.2 console and 911 crossbar the engine sits higher so thee is more of an issue, most use a completely cut away cover like on this one ![]() of course you can always use a cone too, but I'd rather have the stock air cleaner
Thanks Bill. I am using a 3.2 console. I did raise the package tray for clearance but don't think that helps the issue you mention above.
So... find a used or buy a new airbox and then cut it up. I guess that nifty mounting clamp is available from Fabspeed?
