Sonic dB's Avatar
ok
Im
Old 07-01-2003, 02:04 PM
Probably rolled into one of the crevices. You need 2 things: 1) a small adjustable mirror, and 2) a magnet on a stick. THeir use is self-explanatory. I would not start it up until I find that socket.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-01-2003, 02:07 PM
Autodidactic user
David E. Clark's Avatar
Don't even think about starting the engine! Stick the magnet in every crevice you can find. Eventually you'll hook the socket.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 07-01-2003, 02:11 PM
Sonic dB's Avatar
Yeah...Ive got the magnet and the mirror, need more light!
Thanks for the one star rating, thats what this one deserves.
Old 07-01-2003, 02:13 PM
This happened to me once.....work light and telescoping mirror.....I HATE when stuff like this happens.
Warren & Ron, may you rest in Peace.
Old 07-01-2003, 02:15 PM
TSNAPCRACKLEPOP's Avatar
my tools have been running away from home for years............incidently..........whenever i am at my brothers houses, i see that they have every tool i have ever owned in my life, even the "special made" ones.
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 07-01-2003, 02:35 PM
Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
It's not a dumbass problem; just unlucky. Shows you one of the additional uses for crazy glue. Yes, I have used it to hold nuts into sockets and to keep sockets onto tools. clean after you're done and call it a day.
-kb-
Old 07-01-2003, 02:39 PM
If the socket rolled one way, perhaps you can get it to roll the other way by jacking up the left side of the car.
Neil
'73 911S targa
Old 07-01-2003, 03:14 PM
Bill Verburg's Avatar
It sometimes helps to know the lay of the land. here's the top of a Carrera w/o all the mess
and a different view
Bill Verburg
Old 07-01-2003, 03:30 PM
Senior Member
Superman's Avatar
I once let a wing nut fall into the heat exchanger. If you're still in the process of removing the heads, then you'll find it eventually. If it's just a valve adjustment you're doing, then the intake system should not be off and 'open.' I guess I don't understand.
Mocha 1978 911SC. "Coco"
Old 07-01-2003, 03:35 PM
HarryD's Avatar
Bill,
Very nice (albeit gratuitous ) engine picture. Wished mine looked so nice!
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Mr9146's Avatar
Bill,
I love the gratuitous engine shot. Makes me want to take my motor apart for fun.
If he was taking off the valve covers inside the engine compartment, there is no way - unless he doesn't have the engine sheet metal - that the socket would get under the car.
Try sticking a magnet down the plug holes as this is one of the places that sockets like to go if the cover is on when you lose the socket. However, simply dragging the magnet around that side of the engine compartment has been known to help.
Old 07-01-2003, 03:39 PM
That's a 3.2 Carrera, not mine but since i've been accused here's mine
Somwhat different
Bill Verburg
Old 07-01-2003, 03:41 PM
MarkY's Avatar
Send a message via Yahoo to MarkY
Bummer. When you do find that socket, be sure and post where it was you found it. That way, the rest of us will know to look there first when it happens to one of us.
Good Luck.
Mark
1988 Black on Black coupe
Old 07-01-2003, 03:51 PM
Sonic dB's Avatar
Thanks for
Old 07-01-2003, 05:26 PM
Senior Member
Doug Zielke's Avatar
Originally posted by Sonic dB
I just hope that its not anywhere important. Guess I will find out when I button it up and fire it up.
Just be sure to take some pictures of the blow-up for the Mechanical Mayhem Files.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 07-01-2003, 05:37 PM
MY83SC's Avatar
How about this one....Let the Nephew check the oil...and he drops the dip stick into the tank
Mike
83 SC
Old 07-01-2003, 06:19 PM
Team California
speeder's Avatar
That's why they call it a "dip stick". OK, sorry, really.
There are actually not many places that the socket can go, and absolutely nowhere that it can get "inside of the motor". If that was true, I would not be able to wash my motors w/ a garden hose, now would I?
I think that *down a plug hole* is a good guess, have you stuck the magnet down all of them? Otherwise drag the magnet around the top of motor, or just run to Sears and buy a new 13mm socket. And I am relatively sure that you are calling a valve adjustment a "valve job", right? An actual valve job would require the removal and disassembly of most of your motor, so lost sockets would have nowhere to hide.
Denis
Old 07-01-2003, 08:06 PM
Sonic dB's Avatar
Speeder....
Old 07-01-2003, 08:12 PM
when you get that new socket, drop it in the same area where you last saw the other one, except this time tie a string to it, and follow the string to it, and there, nearby, you will find the other socket, then pick out the best one fer yerself, and take the other one back, with the reciept.
cordially, tom and huck, missouri.
ps, buy our book
Old 07-02-2003, 05:13 AM
