Still here
pmax's Avatar
915 Clutch Helper "Omega" Spring Function
Why did Porsche add the helper "omega" spring to the 915 clutch mechanism ?
If it is to reduce clutch effort, as far as I can tell, that remains the same sprung or unsprung though the pickup point is much lower, arguably better in fact, in the latter case.
Old 03-09-2025, 05:27 PM
I think the spring helps lessen the peddle effort when first pushing the peddle in.
Old 03-09-2025, 06:34 PM
I don't know what it is officially designed to do. However, that spring was broken when I bought my '84 Carrera. After I had it replaced, the clutch did seem to work a bit more smoothly, especially when first pushing it in - as porschedude said, above.
Roger
1984 911 Carrera coupe
1972 911T coupe (owned 1978-1995, sold after divorce. . . . bummer)
Old 03-09-2025, 10:01 PM
walt's Avatar
It does give the pedal a snap action feel to it when first depressed.
Walt
82SC 3.0
81SC 3.6
Old 03-10-2025, 04:21 AM
Still here
pmax's Avatar
So, a power mechanism which adds more force to the arms during the initial travel from sprung to unsprung.
Curious, by smoother, do you mean easier ?
The reason I ask is that snap action leads to a non-linear feel in the sense that the foot feels the spring action first then the resistance of the short arm as it moves the TOB is the way I understand it.
Old 03-10-2025, 01:54 PM
Drive a 75 or older car and you will understand. I've considered converting my old 74.
Old 03-11-2025, 06:50 PM
Still here
pmax's Avatar
The earlier simpler mechanisms.
The later 915 standard clutch lever install with the dead space introduced by the two arm omega spring setup
Sorry about the "dirty" pic, not mine, a good example being harder to find that I expected.
In the later 915s there's a spring on the short arm in tension which preloads the TOB fork whereas the earlier variant's all in the clutch cable. Is the cable tension much higher in the latter ? The omega spring assists in the initiation of the clutch pedal movement but how much does it help if at all beyond that phase ? I believe by the time the omega reaches the "red" position, it is largely unsprung. And arguably the leverage of the later version has been lengthened somewhat so that helps.
So I suppose the combination of all these factors contribute to easier clutching. In my SC, the omega spring doesn't seem to do much for this purpose.
Threads of interest.
Examples of the clutch lever backdate, the advantages being elimination of the dead space caused by the 1/1.2mm gap contributing to a more direct linear feel in addition to simplifying the mechanism.
930 Clutch Throw Out Lever / Helper Spring Issue
Clutch Adjustment Help
https://forums.pelicanparts.com/porsche-911-technical-forum/1163942-what-can-you-tell-me-about-my-engine.html#post12278738
https://forums.pelicanparts.com/porsche-911-technical-forum/1178995-clutch-positioning-lever-broken-spring-attachment-2.html
https://forums.pelicanparts.com/porsche-911-technical-forum/417364-convert-early-915-clutch-arm.html#post4033069
Omega snap facilitates cable tensioning which allows long arm to "float".
Old 03-11-2025, 09:31 PM
Still here
pmax's Avatar
Pic of the 74 setup
https://forums.pelicanparts.com/porsche-911-technical-forum/866073-seeking-advice-proper-adjustment-new-clutch-cable-non-omega-915-a.html#post8631169
Pic of the clutch arms at the pedal
https://forums.pelicanparts.com/porsche-911-technical-forum/1181129-915-clutch-cable-adjustment-challenges-2.html#post12532713
Some interesting threads
https://forums.pelicanparts.com/porsche-911-technical-forum/1184310-clutch-adjustment-cant-get-gear.html
Old 09-14-2025, 11:37 AM
KNS KNS is online now
Mine just snapped one day. Not a bad idea to purchase a spare since they are 40 years old or more.
Kurt
Old 09-14-2025, 04:40 PM
