LinkBack | Thread Tools | Rate Thread |
Defrost Light Functionality - On with Lever, or on With Dash/Headlight?
Hey all, just looking to confirm when the Defrost On/Off light is designed to turn on and off.
Should it illuminate only when dash lights are lit?
1983 911SC - Helibronze Metallic L966 |
Yes, always Lights up when light switch is on and not just when levers are up.
Thank you, I am assuming the Heat Levers have no influence on the light illumination. that sound right?
cheers
Yes.
'80 SC Targa Avondale, Chicago, IL |
That light was only put in place because of the USA DOT regulations that all controls are illuminated. My old 1974 914 2.0 had the exact same light. In fact, that plastic cover now in my 911 is actually from my 914 as memento of my 914. For a control that no one looks at, it is silly. Just reach between the seats and and pull the levers without ever taking your eyes off the road.
So as above, it is supposed to come on when the headlights are turned on. It has zero to do with the heater. At least on the manual heat cars. I don't know if the auto heat cars illuminate it when the heat is turned on.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
PCA Member since 1988
When I installed the new carpet kit in my 1973, I didn't put the light back in, figuring I would get to it "later." I don't miss it, so "later" probably will be "never."
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Doing elec work in my 1979 911SC, does the mounting screw provide the ground for it to work?
ive read that the metal on the bottom half of the defrost light assembly is for ground. screw contacts metal "washer", which grounds through sheet metal
Perfect. Thanks for that piece of info. On to the next!
