After the spark plug change from W6DPO to Iridiums that you and Sal proposed, city went to 11-12 as I recall. I still call it 10. My city-drive style has become far more mpg conscious so am probably inching up the city number. Will fill tank over the weekend and post current status. Indeed, many tests. All good. Will keep at it. Exhaust gas analyzer Unit fell through. I looked at new unit prices. Thousands. Can't justify that. Used on eBay... I read some op manuals for systems available. They have multiple parts that need to be included, and system has to have been maintained in certain manner to work accurately. Too risky to get this gear used. Shops that do this? Not any more. Florida did away with this testing years ago. Maybe a dyno shop. Still looking... Would be interesting to see what the exhaust composition is. .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 05-23-2025 at 04:45 AM.. |
Full Send Society
Karl,
Since building my digital gauge which calculates MPG base on injector pulse width, rpm, time and distance moved (it's all a very complicated math equation but that's how it's done) I am able to see my MPG for various states: total, current trip, and current 5 second rolling average (I tried 1 second, 3, 5, 7 and 10 and found that 5 was optimal for human readability). The point here is that while I'm driving (or later with a data log) I can see what my MPG is at any given point and plot that against RPM/speed, GPS location, etc... Since the cam change (stock 2.7 CIS to M1) I have been very cognizant that my low speed, low gear MPG is not great- 10-12MPG. The amount of fuel that the cam demands at low speed to get the car moving is significantly more than the stock CIS cam. Mid range and low load cruising like at highway, it's really quite good; high 20's, even approaching 30. Up top at WOT it goes way back down again as expected. So, on any drive in the city where I have to go from 0 up to 30, then back down to 10, then to 30, then to 40, then 0 then 30, etc... the cam and by extension, car is consuming a lot more fuel than when I'm up to 70 and cruising. Sound familiar? I'm fortunate that I can control fuel delivery and timing with my ECU so I can set my highway cruise lean with a lot of advance to maximize MPG (that coupled with a taller 5th) means getting from home to the fun zone is pretty efficient. 29MPG in this car is better than my old Nissan and often rivals my new Audi. Once I get the the destination, goodbye fuel, but hello fun. I asked about timing but realize that given you're using not using an aftermarket ECU, you might not be able to get that data, or even if you had it, make any changes. I suspect, as I mentioned earlier (a few times) that the cam is just more fuel hungry or that the stock 3.2 timing might not be optimal for the 964 cam... Others have chimed in to share their cam-change MPG-dropping tales as well. I guess my point is to add another anecdote of what happens with a cam change to this puzzle. I'm fortunate to have more levers (ECU) at my disposal than you but even still, city MPG did take a hit. Best of luck and I'll be following along hoping you do find the smoking gun.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
would you happen to have a GPS watch or cycling computer or other method of measuring distance driven? I know you said you checked your ODO based on highway markers, but I wonder if there is some way that it could be inaccurate at the lower speeds while still accurate when on the highway?
I genuinely have minimal cam experience so am proceeding off input like yours and others. Unfortunately for me the input is not one sided. I spoke with Webcam who I'd consider the end all since their cams are installed. Their word is their 964 40/40 cams would not be suspect. Flip side is they may be biased---not saying they are. I hang my hat on their word unless thinking about yours---and I know you have mentioned it earlier. The mystery here is such that I'm open to whatever the truth bears out. Finding it has proven difficult.Let's say these 964 cams are drawing nearly twice the fuel in repeated speed changes. Given the engine moving the same weight car as it was when doing 18 mpg city, I suspect the O2 city readings should read rich. Reason, there's no need for the extra energy expenditure to move the same weight the same distance. If pulling a trailer, makes sense the engine would consume more energy to move the greater weight---the ECU compensating for the load. I may have the principles all wrong here. This is my attempting to make sense of the extra energy that is now being burned---I can't get to a logical conclusion. Can a 3.2's combustion cycle---no matter the cams---process nearly twice the fuel it was previously accustomed to? Does a stock ECU with stock chips "know" there is nearly twice the fuel flow and make up for this with more air flow? Quote:
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Full Send Society
Hey Karl,
ESP32-based. Gotta have access to CAN BUS form an ECU to use it unfortunately in your case... Take my cam talk with a grain of salt as I'm far less knowledgeable that others here with respect to cams. I'm just trying to Occam's Razor this problem. The "tell" for me is that your AFR readings are pretty good, if not exactly where they should be; you're never super rich which tells me that the fuel being delivered by the ECU/injectors/system is all being burnt and that fuel isn't "escaping" combustion and ending up wasted through the exhaust. So either your AFR sensor or controller is way off (probably not) or I don't know... The engine is using all the fuel it's being given/asking for and that just happens to result in a delta of 8MPG since the cam change/engine rebuild. I don't have any other way to explain it other than it's doing exactly what it should. It'll be interesting to see what the oil analysis yields. Over a 10 mile drive, could 1/2 gallon really end up in the oil? That would make the oil more gas than oil by the end of a days' drive...
Karl, did you change anything on the inlet side of the engine at the same time as the cams like an open air box or aftermarket air filter?
Is your oil temperature the same as it used to be in the around town driving situation? |
Agreed on gas in the oil. Math doesn't make sense. But then neither do other things here. So we'll see what's in the oil. I've posted new thread asking for comments on Blackstone who is resource I'm thinking to use for this. Quote:
Full Send Society
I don’t know Karl, Thant’s above my pay grade.
Step back for a moment, are you sure you were getting 18mpg before the rebuild? This whole exercise is predicated on that idea and yet there isn’t any data to support that (at least not in this thread). Is it possible that your odometer is off, tires/wheels not stock, or just that your 40 year old car isn’t as accurate as you think. Sent from my iPhone using Tapatalk
PCA Member since 1988
I use Blackstone for oil samples on all my cars, HD motorcycle, and truck, and have been for 10 years. I am very satisfied with their analysis and dialogue. There are other vendors, but once you pick one, stick with that so you get consistent results across multiple samples (baseline). Unless you are running really long oil change intervals, don't bother spending for the TBN. It almost never gets depleted in normal use.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 05-24-2025 at 03:01 PM.. |
Question of whether my odo is accurate for city driven miles is currently on the table. Am driving tests today to check this. Also filling the tank to get a current mpg. Post this evening or in the morning on these results. Same tires were on car prior to rebuild when it was doing 18 city. Just recently checked toe. All good. Tires have always, and continue to wear on the insides more than the outside. Soon time to swap them side-to-side. Car being older... am thinking "friction." Where is it if it exists? Worn wheel bearings were possible. Tested the wheels. Fronts spin equally to each other but of course less easily than rears. Rears spin equally in and out of gear (with rear end off the ground.) No crunching/grinding feel or noise from any wheel. No rock on any of them. CV were new from a few years prior to rebuild. Prior to rebuild they were repacked. Friction related during rebuild: Crank journals polished and all new case bearings. Crank spun after closing case = silky smooth. Rods: new small end bushings, large ends rounded, both done by Porsche pro shop---and I measured each afterwards being precisely on. New wrist pin. Also measures spot on. In spec pistons and cylinders were recycled. New Goetz rings sequenced & oriented correctly. New cams fit neatly. 1 new rocker. New chains (on old sprockets.) Heads fully restored by Xtreme---new valves, grinds, new guides, new springs correctly oriented. 2,000 rpm break in for 20 minutes. Break in oil & filter changed. New clutch disk and pressure plate. Part of current diagnosis: Compression tested good and sufficiently equal among cylinders. Without plugs, crank was spun by hand with tightened fan belt---smooth. Fresh gear oil remains full---just checked level. Fan/alternator spins easily. Brakes check, all OK. Where else could friction be? Got more into doc you sent. Impressive reference. Will be using it. Thank you. . Quote:
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 05-25-2025 at 07:22 AM.. Reason: Added details to "friction" notes |
Now recalling discussion that led to my going from stock 3.2 config to installing: 964 cams, 1.45 overlap, SSI exhaust, Dansk muffler… Among other selling points, it was the “engine would breathe easier—more air flow.”
…Some more recall. 930s I’ve owned: 9 mpg city. Based on mpg alone, and assuming air flow through an engine is an mpg factor, I raise the question of whether my or ANY normally aspirated 3.2—with the mods noted—can possibly achieve nearly the same air flow, and so nearly the same fuel demand as a turbo charged 3.3 does? .
Full Send Society
More air requires more fuel.
Odometer test
Was done with Google maps. Stride app was not run. Route followed had 2 legs. Combined route total per Google = 12.3 miles. Main odo reads same as trip. ![]() ![]() Google Maps, routes 1 & 2. ![]() ![]() Start and end mileage for Google route followed. Current city mpg = 11.55 Fill at Westar. Premium. Done at same station & pump as last time. Fill process is also the same… nozzle position in filler neck, low trigger setting, allowing pump to cut off and no topping off. Improvement from original 10... Could be any of following: my driving habits being honed for economy, change of spark plugs (W6DPO to Iridiums), change of gas station (Shell to Westar.) At fill early on in testing, 9 and a fraction mpg was managed. Was with slightly heavier foot than now,W6DPO plugs, and filling at Shell. All mpg readings following rebuild are without AC compressor installed. ![]() ![]() Gallons of fuel loaded and driven miles. ("KM" refers to speedo, not trip odo.) ![]() ![]() Gauge before and after fill. (Needle gets to 4/4 if tank is manually topped off. Am not topping off for mpg tests.) .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 05-30-2025 at 11:00 AM.. Reason: "Odo" changed to "Odometer" |
... Indeed.
If increased fuel use is a result of rebuild mods allowing so much more air flow than there was prior to the engine's rebuild, and taking into account all the tests done to date (see first post) revealing no mechanical or electrical faults that have not been corrected---notably parking brakes dragging, and brake booster failing while testing was in progress and that too fixed---then there come the wideband readings suggesting the engine running relatively on target AFRs... combo of mods do have plausibility. I can't fathom a 3.2 processing this much air/fuel but I don't know this stuff inside & out. So my reluctance in this regard is pure speculation. ...Restrictor plate(s) come to mind. Edit: Looking at various sources to see if restriction makes sense, there are claims that improved exhaust air flow INCREASES MPG due to the lessoning of back pressure. That makes sense. But given more air flow, that would sensibly call for more fuel. Regarding the capacity of a 3.2's cylinders for air flow, I came upon calculations posted by Sal: Let's keep this simple by simply just mathematically calculating max air flow in Liter/min and assuming a Volumetric Efficiency of 1.0 Am after an air/fuel equation to apply to 3,000 rpm. Working on it. Idea being to see how that fits a 3.2's expected mpg. .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 05-27-2025 at 05:22 AM.. |
Full Send Society
Karl,
Have you by chance changed your flywheel from the stock one to a lightweight one? I ask as the lightweight flywheel can/may have a negative effect on mpg in that more rpm’s are needed to help it spin (as it has less inertia), there’s less coasting (again less inertia) and as it spins up faster, it’ll achieve higher rpm’s and that can require more fuel At highway speeds it should have no effect. Maybe a small piece of the puzzle as this far there hasn’t been a smoking gun. Sent from my iPhone using Tapatalk
Tested:
AFM intake air temp sensor = OKTests are always repeated to confirm the results repeat consistently. Specs applied for this are from: ![]() Thank you Julian. Notes & spec references: AFM Intake air temp = 1.73 ohms. Suggests air temp being 15 - 30 degrees C / 59 - 86 F. Ambient is 75 dF so this makes sense. ![]() ![]() Engine temp sensor Two ohm readings were taken to test the engine temp sensor. First reading was taken while engine was warming up. Second when engine reached op temp, 210 in this engine’s case. With dash gauge temp at hash mark just below 210: Ohms = 287. This puts #3 cylinder temp in the 80 C / 176 F range. Makes sense relative to dash temp gauge reading. Calling this OK. With dash temp gauge at 210: Ohms = 42.6 This doesn’t fit specs. Ohms should be 160 - 210 range. Either sensor is off or temp gauge in dash should read much higher. Ohms climbed slowly as engine cooled. This correlates with specs. ![]() ![]() ![]() ![]() ![]() Not sure what to make of the engine temp sensor results. .
Both the IAT and the CHT sensor have the same temp to ohms spec. Here's the full spec:
Temp C Ohms -30 4700 -20 4500 -10 4300 0 4000 10 3700 20 2500 30 1825 40 1150 50 943 60 735 70 528 80 320 90 253 100 185 110 170 120 155 130 140 140 125 150 110 160 95 170 80 180 65 190 50 200 35 210 20 220 5 But once the CHT sensor ohms drop below 180 ohms the sensor no longer does anything to fueling. Meaning, if ohms are between 0-180ohms fueling change factor is simply 0% This is why you can remove the sensor in a fully warm engine and bridge the 2 pins with piece of wire (0 ohms) and engine should run fine. Wile I agree changing a sensor that's out of spec is a good idea, this is not your issue with poor MPG. Even if the sensor is below 60ohms it has no effect on fueling.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
^^^ Sal... Thanks for those details. Bridging CHT pins to keep a warm engine running... nice work-around.
Tested:
Speed sensor - static resistance = OKTest procedure is per Specialized ECU Repair: Disconnect harness plug from ECU. Multimeter, set on ohms, connects the following pins: Speed sensor: connect pins 8 and 27. Ohms to be between 600 - 1600. Reference sensor: connect pins 25 and 26. Ohms to be between 600 - 1600. ![]() ![]() Speed ![]() Reference For dynamic testing: Check car’s battery has 12+ volts = OK (12.6 v) Gearbox in neutral, parking brake ON. Multimeter set to AC voltage. Speed sensor: connect pins 8 and 27 with multimeter. Crank engine. Voltage should be greater than 1.0 v = OK (is 2.6 v) Reference sensor: connect pins 25 and 26 with multimeter. Crank engine. Voltage should be less than 1.0 v = OK (is 0 v) .
