Close Dave (Loren) but the two comparator outputs from 139 are evaluated by the IO port P1.6 and P1.7 lines of the MCU. The two interrupt inputs of the MCU are used to decode engine speed and TDC signals from the custom flywheel amplifier.
From a hardware perspective there was a very small fraction of early Euro DME boxes that came w/o the components for the O2 sensor. My guess is Bosch quickly decided that making different hardware isn't worth the savings over the additional logistics required to track the different models. But it's the code on the EPROM that decides whether inputs to P1.6 and P1.7 are used to modify the mixture or simply ignored. My bench-test fixture makes that very obvious when simulating full rich or full-lean O2 signals and then watching the injector duration changing at a given load/RPM/CHT point. And the time constant of these mixture changes is on the order of 5 - 10 seconds and not momentarily. But hey, I am just a hobbyist and talk about data I collected over the last 20 years I've been doing this. @Steve, please drop off your 911 and leave the pink slip in the glove box - preferably with a stock chip ![]() Quote:
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 Last edited by ischmitz; 06-24-2025 at 12:47 AM.. |
Out of interest, this is another unit I acquired for parts a while ago, can anyone recognise this ECU by the chips fitted, my original assumption was/is that its a very early 3.2 unit, but...
Ant. ![]() ![]()
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
10 mpg 3.2 - can’t find where the fuel is going
I can’t quite make out the EPROM part number but since it’s missing the components for the O2 sensor signal it’s got to be an early ROW box. There is an unpopulated area near the heat sink for the ignition final driver.
Can you read and post the Bosch number on the EPROM? I seem to see 1 267 355 027 and that is the earliest code I’ve ever seen for a ROW box. And 1 267 355 028 is the corresponding U.S. version.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 Last edited by ischmitz; 06-24-2025 at 01:36 AM.. |
Dave |
My error in not having the wiring diagram in front of me for the actual pin numbers. Quote:
Too slow of a response time to the O2 signal will cause idle hunting/oscillation. When normal idling occurs, there's a small 25-50 RPM hunting.
Dave Last edited by mysocal911; 06-24-2025 at 03:05 AM.. |
Thanks, the number you quote from the chip I am mostly in agreement with, however; its not clear whether the third from last digit is a 0 or a 4, tried looking at it using various methods.
Ant. Quote:
I gathered that it had various components missing for possibly the 02 monitoring, hence the reason it was purchased here in the UK, we didn't use' or have much need for such methods of monitoring emissions at the time.
A bit more info on this unit; with it installed, my car starts fine, idles great, and will rev up easily until it reaches around 2,700rpm, then it will hesitate, but if you give it a bit more throttle it will go past that rpm range with a struggle, hence my initial hesitation in accepting it as an early 3.2 ECU. Ant Quote:
Still here
Learned a lot from what mysocal and ischmitz have posted here in this forum. And that they participate regularly in this forum is much appreciated. Anyway, enough of that, back to our OP's saga ... |
It's got to be a zero. There was no Bosch number with a 4 in that position. I also noticed the two metal-can transistors and the ribbon cable looks like the early paper version. So this is one of the really early boxes. Check the IC for 4-digit date codes. They can be like 3583 meaning it's the 35th week of 1983. I bet you you'll find stuff from 1983.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Dave |
Understood,
Yes, paper ribbon between boards, chip set pick below; Ant. ![]()
Looks like the ADC was made in week 15 of 1983 and the MCU in week 26 of 1983. So the box was probably made in the second half of 1983.
Thanks for the info
![]() Ant.
ECU was found to have a number of issues. Systems Consulting corrected them. Unit is on the way back to me from CA.
In the meantime, I've posted Blackstone's analysis for the Motul synthetic oil that's in the case. Virgin oil was also tested to have a base line. It's perhaps mute at this moment to consider fuel in the oil but this analysis was started a while back for the interest of it and to check one more possibility. Seems worth it to share the results, be they as they are. https://forums.pelicanparts.com/porsche-911-technical-forum/1179640-blackstone-oil-analysis-motul-synthetic-20w50-sloppy.html#post12489969 .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 06-30-2025 at 08:29 AM.. |
Full Send Society
What were the ECU issues and how did they affect the fueling/timing/etc...?
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
So the Blackstone report did show some fuel in the oil. At least there was no antifreeze!
![]() It will be interesting to hear of the new fuel mileage with the repaired DME. Good Luck. By the way, I recently drove my 911 for 450 miles on one tank of gas. It is possible (maybe) that I might have been running at 90 for the trip. 3,600 RPM, and 19.5 gallons used. 23.07 MPG. At 70 or 75 I can go 500 miles, but who cares. Interstate 70 in Kansas and Colorado is pretty boring and goes on forever.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Let's understand what issues were found and what Systems Consulting did to correct them. Also why is Loren gaslighting everyone here posting under his new moniker mysocal911 peddling his business. I find it hard to believe that people vote with their dollars for such nonsense and lack of integrity.... Quote:
