917_Langheck's Avatar
DaLorenve will need to detail all, since he demands that from everyone else.
Old 06-30-2025, 11:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #261 (permalink)
LJ851's Avatar
Karl, have you received your repaired ECU yet ?
Old 07-07-2025, 06:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #262 (permalink)
scarceller's Avatar
Will be interesting to see if the MPG issue gets resolved, hopefully you can articulate what exactly was found to be wrong with the DME?
Originally Posted by Discseven View Post
ECU was found to have a number of issues. Systems Consulting corrected them. Unit is on the way back to me from CA.
In the meantime, I've posted Blackstone's analysis for the Motul synthetic oil that's in the case. Virgin oil was also tested to have a base line. It's perhaps mute at this moment to consider fuel in the oil but this analysis was started a while back for the interest of it and to check one more possibility. Seems worth it to share the results, be they as they are.
https://forums.pelicanparts.com/porsche-911-technical-forum/1179640-blackstone-oil-analysis-motul-synthetic-20w50-sloppy.html#post12489969
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 07-07-2025, 09:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #263 (permalink)
Discseven's Avatar
Update...
ECU should depart CA from Systems Consulting for Miami tomorrow.
When I receive it, am installing new tie rods. This, given the recently found worn passenger side unit. While this seems to have nothing to do with the mpg given the test done with Dean's ECU, I want it removed from the equation. This replacement has not been done while the car sits idle as doing so in my condo's parking garage... car up in the air as is needed would draw unwanted attention. To get stuff like this done, I drive off premise to a spot I like to work at---this is condolife.
Then onto city & highway mpg runs. Double up the mpg runs for confirmation. Of course I'll post mpg results along with what Systems Consulting accomplished with the ECU when this info is in hand.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-09-2025, 08:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #264 (permalink)
Just as a reference, today I drove 301 miles and used 11.07 gallons of gas. 27 mpg when driving mostly at the speed limit, 60 to 75 MPH.
Old 07-09-2025, 07:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #265 (permalink)
Brilliant!
Ant.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 07-10-2025, 12:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #266 (permalink)
Discseven's Avatar
Major delay on my part. LIFE gets in the way sometimes. Pardon me for this.
Systems Consulting has delivered on schedule as they promised. I'll get on with testing mpg this week. Plan is to post results over the weekend at some point.
Karl ~~~
Old 07-21-2025, 06:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #267 (permalink)
Full Send Society
Karl, now that you have the DME back and presumably have completed the transaction, can you tell us what exactly was wrong with the DME and what exactly was done to rectify it?
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 07-21-2025, 04:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #268 (permalink)
Discseven's Avatar
Systems Consulting ECU
My ECU went through various oscilloscope and chip tests. Fault is in the processor. With my ECU being a “rebuilt” unit from Vertex, and Vertex being a proven dubious source for ECUs, Systems Consulting chose to provide me an ECU that they alone have handled. My unit is cored. Within the ECU sent me from Systems Consulting, solder has been reflowed and anti moisture coating applied to the boards, these being to extend the units durability. Installed is a 358 eprom as an update. Unit was delivered to me several days ago as promised… pardon me as I’ve had to deal with distractions so mpg testing had to be set aside momentarily.
Test Results:
Systems Consulting ECU with 358 eprom:
Starts first crank
Startup idle holds at 1300 rpm…
Then drops slowly to 925 rpm within 60 seconds of start
Smooth idle - cold or warm
Strong pull to redline with zero hesitation
City = 19.001 mpg
Highway = 28.18 mpg
City
Highway
Fuel fills and refills were done as always: same station / same pump / same fill technique. Odo is proven accurate. There are a total of 4.3 city miles within the highway miles—distance between gas station and highway. Planned to install new tie rods and check struts for straightness before running highway but those had to be postponed for a few days.
Innovate wideband system: yanked
Innovate system has recently been serving up one malfunction after another. Latest issue: Whatever controller is at the end of the dual controller daisy chain, that end-controller’s trace line is always measurably higher than the other. And this higher line’s oscillation has a much greater amplitude than the lower trace line. Swapped controllers… same scenario albeit with the trace lines inverted. Innovate tech support = useless. Keeping reliable data going here has become too time consuming to deal with. LC-2 system is now shelved. Bungs are plugged. In contrast, LogWorks software has been faultless.
To each of you who participated with me in this journey, thank you! Thread discussions, PMs, emails, phone conversations, documents and images shared, and all the tests & checks suggested, the loaned ECU… I’m in great appreciation for each of you!
Dave, special thanks to you for arranging the ECU solution with Systems Consulting for me as you did. Great company to work with!
Systems Consulting… much admiration your way for taking on this ECU puzzle as you have done. Start-to-finish, your communications and handling of this matter has been World-Class. That I’ll not be plagued by “sleeping” faults given my ECU’s dubious origin… THANK YOU for covering that base, and for all that you’ve done for me. From the get go, it’s been a truly enjoyable association with you! And the ECU you provided me… STELLAR!
www.systemsc.com 310.545.3716
Karl ~~~
Old 07-27-2025, 08:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #269 (permalink)
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Cool
So Loren exchanged the unit because he couldn’t fix it? Is it only me feeling gaslit by the statement “the fault is in the processor” because the DME came from a dubious source?
The 8051 MCU can be swapped in 5 minutes if it really is root cause. Dave (aka Loren) makes that point in another DME thread. https://forums.pelicanparts.com/porsche-911-technical-forum/398595-calling-motronic-experts-ic-information-4.html#post12494177
The “upgrade” to the 28-pin chip conveniently runs all code from external memory to where any generic 8051 will do. So why not just swap in a new 8051?
He probably gave you a reworked 924 or 944 DME with non-911 compatible ROM code on the 8051 and kept your “core” to make it an early 911 DME for the next paying customer. The “reflow” nicely hides the other rework required….
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 07-27-2025, 10:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #270 (permalink)
Missed seeing this in the post (#270) by the OP?;
So you're unaware that the 924 DME ECM uses RCA chips & NOT an 8051!
Did you miss seeing what the "rebuilt" core (see OP's post 176) looks like?;
The replaced ECM has the later better fiberglass circuit boards, see the image in post #270.
Given that the OP had consumed so much time & effort with his "rebuilt" ECM, and to minimize any future problems, Systems Consulting just provided another better ECM.
Dave
Old 07-27-2025, 11:03 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #271 (permalink)
ischmitz's Avatar
Oh - did I miss the memo where the sheet metal covers are serialized to the PCB stack
If you’re that standup guy you want to portray yourself then why not spell out what was wrong with the DME that led to increased fuel consumption. And if you don’t know then say “I don’t know” instead of first declaring it as “fault in the processor“ and now saying it’s due to a screw/nut instead of rivets in the heatsink.
Sadly these statements sink to the level of „…replaced an out-of-spec transistor…” and to me this is disrespectful to a community that wants to learn.
Old 07-27-2025, 11:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #272 (permalink)
For more info, you need to call Systems Consulting, the number is on their website; www.systemsc.com
Dave
Old 07-27-2025, 12:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #273 (permalink)
Great job Karl and nice write up and troubleshooting. You must have the most sorted 911 on the road now!
Rutager West
Old 07-27-2025, 12:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #274 (permalink)
It is great you finally have normal fuel mileage. It just seems impossible that the vehicle can use that much fuel, and not blow black smoke.
I sure can't argue with the documentation you have provided, and I have to accept the proof you have provided. Welcome back to the land of normal fuel mileage!
Old 07-27-2025, 01:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #275 (permalink)
Karl,
Congratulations on a nice new running car 😉
As a BTW, there was a recent Klassik ATS video that demonstrated the disconnect between a running air:fuel meter showing condition A, and a professional gas analyzer showing condition B at the same time. Condition A said the car should run fine, but it ran like scheiße. Once sorted and set per the professional gas analyzer the car ran correctly. Kinda puts one off on those chinesium a:f meters.
Old 07-27-2025, 02:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #276 (permalink)
I have to admit to being curious as to why the original ECU was so far out of spec that it needed to be replaced, However; I am glad to hear that the OP [Karl] now has a great running car, with decent MPG.
Ant.
Nikola Tesla
Old 07-28-2025, 01:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #277 (permalink)
Full Send Society
I’m still curious as to why all the data logs Karl took presented relatively ok AFR but the mpg was so off target and how the ECU being “out of spec” contributed to the issue.
I’m glad that Karl has his car back to where it should be but we still don’t have a REASON why the ECU was the culprit.
Was it a PW issue with the injectors? Was it some other monitoring loop? What fault in the ECU can cause the car to run fine but with low MPG?
This isn’t about pointing fingers, it’s about a massive thread that the whole community troubleshot being resolved so that the next person who has this issue can retrieve a solution and a cause for the issue.
-Julian
Old 07-28-2025, 04:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #278 (permalink)
Nikola Tesla
Old 07-28-2025, 05:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #279 (permalink)
proporsche's Avatar
yup,as ant, showdown too.... mentioned, maybe is a secret Loren does not like to share----kinda pointless thread than!!
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 07-28-2025, 05:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #280 (permalink)
