Post 16. Gets them off right now.
Unfortunately I don’t have a welder… for the moment I’m just heating it up a bit and then spraying penetrating oil on it every day. Will take another shot at the fill plug this weekend.
This evening’s adventure is cleaning up and replacing some shims in the distributor which has come with its own set of mysteries. |
Bee's wax sometimes works better than some penetrants. Get the plug real hot and swab it all around.
^^^ I’ve heard crayons work as well. Is that true? I suppose it’s a wax, like beeswax?
gearhead
Another trick is to quite literally hit it with a mallet. You need to break up the corrosion to get it to let go. I use this one all the time following heat to shatter the thread lock that has been applied to ring gear bolts (which are also torqued to around 150ft/lbs.).
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
It's a 914 ...
I like Matt's suggestion. Stick a drift in the middle of it and give a few moderate hits with a hammer.
Don't be afraid to heat it with a propane torch. It won't hurt anything. A heat gun won't do anything. You can try alternate cycles of heating the plug and the surrounding area, and apply more penetrant while it's hot. It will eventually give. |
I have heated the case with MAP torch.
With the socket already in I have shock it with Bio Freeze (liquid nitrogen) Apply torque in either direction. Everything comes out effortlessly Basically same technique you use when pressing bearings No brainer
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
Like you I had a difficult time with the drain plug. Got it loose with a breaker bar but before removing and draining the transmission I thought I'd make sure the fill plug will come out. Good luck.
Find Spoke's LED Products: www.spokeworksled.com |
Good luck with the fill plug. Have you tried the drain plug yet just to see if it too is seized?
Hi
The tapered threads of the plug, provide the seal which stops the trans oil from leaking out. This means that chances of getting penetrating's oil in are not so good. Breaker bar and pipe extension is first step. Post 16 is second option. Cheers |
Still here
Bet #16 is due to the heat not the socket.
ok..i wonder if you have the right socket?? It should really look like this one...so my suggestion get the it and with a bar it will come off
Ivan ![]() ![]()
1985 911 with original 501 587 miles...807 226 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Hey REVerend --- feel your pain. Looks like you tried most suggestions. I suffered this same issue two years ago w my 83 SC. The car was lifted on jack stands. I could barely reach in there to attach the allen and an extension. But, no way to get leverage w/o risk shaking or tipping the car.
In the end I paid my local air cooled tech to do it. W/O a proper lift, it would have been very difficult and quite risky/dangerous to try to remove myself. Here's the post/thread, starting from Post #20.... https://forums.pelicanparts.com/porsche-911-technical-forum/819484-fill-plug-915-gearbox-has-blocked-clearance.html Good luck!!!
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil |
I’m gonna talk to a mechanic about it soon. |
Awesome! That sounds much more stable and safe than just jack stands.
Can you discern the socket that Proporsche uses? What is distinct/special? Looks like a typical 17 mm, no?
