Post 16. Gets them off right now.
206 637 4071
Old 07-23-2025, 05:47 PM
Unfortunately I don’t have a welder… for the moment I’m just heating it up a bit and then spraying penetrating oil on it every day. Will take another shot at the fill plug this weekend.
This evening’s adventure is cleaning up and replacing some shims in the distributor which has come with its own set of mysteries.
Old 07-23-2025, 05:51 PM
Bee's wax sometimes works better than some penetrants. Get the plug real hot and swab it all around.
206 637 4071
Old 07-23-2025, 06:43 PM
A930Rocket's Avatar
^^^ I’ve heard crayons work as well. Is that true? I suppose it’s a wax, like beeswax?
Old 07-24-2025, 03:13 AM
gearhead
Another trick is to quite literally hit it with a mallet. You need to break up the corrosion to get it to let go. I use this one all the time following heat to shatter the thread lock that has been applied to ring gear bolts (which are also torqued to around 150ft/lbs.).
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-24-2025, 03:18 AM
It's a 914 ...
stownsen914's Avatar
I like Matt's suggestion. Stick a drift in the middle of it and give a few moderate hits with a hammer.
Don't be afraid to heat it with a propane torch. It won't hurt anything. A heat gun won't do anything. You can try alternate cycles of heating the plug and the surrounding area, and apply more penetrant while it's hot. It will eventually give.
Old 07-24-2025, 04:36 AM
faverymi's Avatar
I have heated the case with MAP torch.
With the socket already in I have shock it with Bio Freeze (liquid nitrogen)
Apply torque in either direction. Everything comes out effortlessly
Basically same technique you use when pressing bearings
No brainer
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 07-24-2025, 04:45 AM
spoke's Avatar
Like you I had a difficult time with the drain plug. Got it loose with a breaker bar but before removing and draining the transmission I thought I'd make sure the fill plug will come out. Good luck.
Find Spoke's LED Products:
www.spokeworksled.com
Old 07-24-2025, 05:51 AM
I haven’t even touched the drain plug yet…
Old 07-24-2025, 06:14 AM
spoke's Avatar
Good luck with the fill plug. Have you tried the drain plug yet just to see if it too is seized?
Old 07-25-2025, 05:27 AM
Haven’t touched the drain plug apart from giving it a spray of penetrating oil.
Old 07-25-2025, 06:08 AM
Hi
The tapered threads of the plug, provide the seal which stops the trans oil from leaking out.
This means that chances of getting penetrating's oil in are not so good.
Breaker bar and pipe extension is first step.
Post 16 is second option.
Cheers
Old 07-25-2025, 12:21 PM
Still here
pmax's Avatar
Bet #16 is due to the heat not the socket.
Old 07-25-2025, 12:44 PM
Yeah I imagine that helps… last night I got it cleaned out and it looks like it’s beginning to round out which means welding it may be the only option
Old 07-25-2025, 01:11 PM
proporsche's Avatar
ok..i wonder if you have the right socket?? It should really look like this one...so my suggestion get the it and with a bar it will come off
Ivan
1985 911 with original 501 587 miles...807 226 km
Old 07-25-2025, 01:45 PM
Hey REVerend --- feel your pain. Looks like you tried most suggestions. I suffered this same issue two years ago w my 83 SC. The car was lifted on jack stands. I could barely reach in there to attach the allen and an extension. But, no way to get leverage w/o risk shaking or tipping the car.
In the end I paid my local air cooled tech to do it.
W/O a proper lift, it would have been very difficult and quite risky/dangerous to try to remove myself.
Here's the post/thread, starting from Post #20....
https://forums.pelicanparts.com/porsche-911-technical-forum/819484-fill-plug-915-gearbox-has-blocked-clearance.html
Good luck!!!
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil
Old 07-25-2025, 02:34 PM
Ivan
I didn’t realize there was a specific socket and was using 17mm hex bit
Old 07-25-2025, 02:53 PM
Good luck!!!
I have it on my quickjack, not as good as a full up lift but it’s fairly solid. Additionally I added wood blocks front and rear which make it very solid. Clearance to get at it isn’t terrible either from below or through the left rear wheel well.
I’m gonna talk to a mechanic about it soon.
Old 07-25-2025, 02:58 PM
Awesome! That sounds much more stable and safe than just jack stands.
Old 07-25-2025, 03:20 PM
Yeah that's what I used as well.
Can you discern the socket that Proporsche uses? What is distinct/special? Looks like a typical 17 mm, no?
Old 07-25-2025, 03:21 PM
