The bigger concern is the relatively small size of the muffler cavity, I could barely get a 3.0 SC to pass Lime Rock sound(on most days) w/ off the shelf mufflers that size.
These also flow quite well there are little things that can add to the flow efficiency and power one thing would be to extend the inlets into the cavity an inch or so(see what the factory does) and use a bell shaped transition on the end. Once the initial expansion has occurred it's all about absorbing reflected sound waves and efficiently moving the cooling and contracting gasses to the outlets The 993 GT2 Evos added a reverse cone to the outlets i don't know that it did any good after the muffler but the factory thought so, It certainly is very helpful for open exhausts
How much does fiberglass or other mat on a straight through muffler help vs an empty but larger muffler cavity? We could make a muffler chamber from 6” tubing x 36” long with the inlet and outlet pipes curving into the chamber so they’re not directly across from each other like a modified banana muffler is. I’ll draw it up tomorrow.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Bill, you have often extolled the virtues of the Fabspeed muffler. I thought you posted a cut away view of one at some point. Or maybe I saw it elsewhere where. Do you happen to have that internal design? Since you like it (so does Steve Wong and others) it might help Dave with his?
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles Last edited by Duc Hunter; 08-06-2025 at 05:29 AM.. |
The thing is you do want as large a cavity as possible iff you have cams w/ decent overlap, The biggest and best cavity is an open exhaust, the bigger the cavity the bigger the return acoustics that the cams can use. To suppress noise you need f/s or ss wrap or ss scrubble and the more of of this the more noise suppression, most efficient flow comes from solid , w/ perforated pipe a close second. You have to integrate al of this into the available volume. I often though that ex[anding a bannana type into the aft ends of the rear wheel wheels, sort of like a semi side muffler extension ala 993 , 996, 997 etc. A 993RS 3.8 w/ separated cat bypass and only 993 n/a or 993 tt side mufflers is perfectly ok at LRP w/ turndowns at the exit tips. Even modified 993 sides like the Fister 2s are ok in that environment.
I did ask Joe about the interior design and was assured that there is no head on impingement to flow, but beyond that he wanted to keep details close. I suspect that there is no expansion cavity as w/ the bananas or 993 type side mounts but the stock 993 or even an RS doesn't really have a lot of TDC compression overlap any way.
A couple more designs.
First one is two chamber (per side) with no packing/fiberglass. Overall muffler is 36" long x 6" diameter so each chamber is 9" long. ![]() The second one is three chamber (per side) with packing/fiberglass in the central chamber. Each chamber is 6" long. ![]() Thoughts? EDIT: I just checked the weight of these two designs and it's not good. They're fabbed from 18ga or 0.065" 304SS and both weigh about 45 lbs vs about 17 lbs for the dual in/out off the shelf muffler including the inlet/outlet pipes!
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) Last edited by David; 08-06-2025 at 11:20 AM.. |
the second is better but a third chamber isn't going to do much, i'd like to see long perforated /wrapped pipe, exiting into a larger central cavity and ovalized case ![]()
I wonder if the WK headers spacing might be compatible w/ the Fabspeed muffler
It really is a great muffler and Skinnerd's modified banana is also a great design some other designs ![]() ![]() Found Fabspeed internals, bothe sides dump into a central cavity w/ angled ends ![]() ![]() Some Burns implementations ![]() ![]() 964 RS/LW ![]()
A few more
SC/RS rally
![]() Singer ![]() Again I always liked these ![]()
I made something simple when I installed my 3.6 engine.
A few 90 degree bends and 4 cheap small simple straight thru mufflers. Its not loud and according to the dyno its not a disaster. Please don't look at the welds! But they have held up. ![]() ![]()
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Almost as if the the opposing exhaust pulses are 'crashing' into each other. I don't know the best way to go but it sure looks like you are more than capable of solving the problem. Looking forward to seeing the outcome!
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Does the bottom one have some kind of mechanical valve?
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud) '70 914/6 Race Car (Faster and Louder) '71 73RSR tribute vintage race car 3.0 '68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox '81 Magenta IROC clone in progress 3.6 varioram/G50 |
Do you have any sound clips? Video?
yes, you can see the tool insertion points to manually turn the valves
Nah, nothing good. It sounds deep, not sharp at all. I manage 95db flyby on trackdays.
Only some crappy in car audio from track days. https://www.youtube.com/watch?v=sMmwq6w8mwU
Lots of good ideas here but the problem statement is to have IROC RSR spacing on the rear outlets which severely limits the options.
I could not find the Fabspeed muffler on their website that Bill likes but I have emailed them to check if it's still available. I would like to find out the overall length of the muffler to see how it fits. Here's my final design if Jay's onboard. It would allow coming back and installing a larger 22" long muffler if it's too loud and if a larger muffler is found or fabricated: ![]()
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) Last edited by David; 08-07-2025 at 06:57 AM.. |
I like that and feel the pain on the RSR width challenge. I would mimic the fabspeed internals, and maybe make teh box as wide as possible before encroaching on your mandrel bends for teh existing. Based on your drawings that could be as wide as 22" on the bottom. You could even go wider possible on the top half, using a tighter bend similar to the outlets, and gain some chamber size and sound deadening. Just a thought.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
![]() That last drawing is very similar externally to what many of us had from Fabspeed, Borla etc. This is my old Fabspeed
I spoke with someone named Andrew at Fabspeed. He told me they discontinued the exhaust Bill likes in favor of their x-pipe design. He said it was both quieter and better on the dyno.
He did tell me he would check if they had any stock left of Bill's type muffler and was supposed to send me dimensions and/or drawings. So far I have only received photos of what it looks like installed from him. I'll update the thread if I hear back.
