Does anyone have smooth running PMO cabs
Looking at the PMO carbs.
Have read a lot of reviews and installation threads. Do any of you have a smooth operating and reliable PMO set up? How do you handle cold morning start ups? Thanks Michael 1979 911 sc. M&K 2 in 1 out. SSI’s 3.0 Liter. |
Yes many of us
These carbs are fantastic when tuned properly Issue is finding someone who actually knows what they're doing
Instagram.com/timofthevalley |
Yes, smooth. 2 pumps when cold and throttle stop until warm. When warm just turn the key with slight throttle opening.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Just make sure you will have the fuel PMO regulator in the system.I did this for a guy who would drive his 911 with Webers for 10 years always crying due to the a lot of fuel in the exhaust.So i got him PMO from the company and here is how it sounds..he was happy camper
Ivan https://www.youtube.com/watch?v=nuDIc7ypJmE
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Hi
"How do you handle cold morning start ups?" These carbs have no choke for starting enrichment. Your only enrichment tool is the accelerator pump. For Webers: Allow electric fuel pump to run and fill float chambers Apply full hand throttle Give gas pedal a couple of pumps. Crank engine with starter while pumping gas pedal until engine fires. If RPM sags give another quick pump of gas pedal to richen mixture via accelerator pump As engine warms up, reduce hand throttle to zero. Cheers |
Ivan
Hi
all good stuff --but he has 1979 911SC no hand throttle ;-) True; and if it has Carbs it needs one retrofitted. :-) Lots of good info here: https://forums.pelicanparts.com/porsche-911-technical-forum/639786-hand-throttle-lever.html Cheers Last edited by Magyar Kiwi; 09-22-2025 at 02:19 AM.. Reason: Add link with more info. |
Been running PMOs for several years on the 2.2 in my 1971. Amazing throttle response, no surging, no flat spots, just smooth acceleration. Also no popping on deceleration. On my recent roadtrip from Phoenix to Monterey I experienced temps from the 50s-100s, plenty of elevation changes, and a mix of highways and backroads. Ran perfectly the entire trip with no issues whatsoever and I averaged 24mpg.
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
https://www.youtube.com/watch?v=Cd1s112bCOY Ivan
I haven't found the "need" for a hand throttle
Although I'd like to have one for warm ups and "cruise control"
I agree, while the hand throttle is nice to have it isn’t mandatory. Unless ambient temps are below 40 degrees, the engine should be warmed and settled into a smooth idle in 2-3 minutes max, much sooner when ambient temps are 70 degrees or warmer.
Full Send Society
Hand throttle is very nice to have on cold mornings and as a poor man’s cruise control it’s great to be able to stretch one’s leg for a few mins.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
