911 3.2 motor number issue
Hello everyone.
I recently purcashed a 911 3.2 that was previously registered in my country, but originaly it was a US car.
I run into the problam that in Hungary a COA is requirement for it to have a license plate.
My car however has an overstamp on the second digit of the engine number. The engine number is 64K02*** and on the second digit there is an overstamped 3 on the 4(or the other way around). The car was succesfully registered in the Netherlands, Austria and Hungary before with this issue that I know of.
The car was in use with this problem for at least the last 10 years. It was printed in on all of its previous documentation, however now the exam place refuses to pass it since it has been tempered with.
My questions are:
why would anyone temper with the original destination country? I don't see any upsides to this?
Is it a possibility that this is an original factory error? Has anyone see anything like this before?
Is there any way to get a COA for such an engine?
Did they stamp the engines separatelly for US and ROW meaning: does a 64K02*** and a 63K02*** exist or the serial itself is unique and either one exists but not both?
+1 the car is not matching numbers (it is an '87 car and this motor is an '89) so I cannot get a build sheet or a PPS
Any insights would be helpful.
[IMG] https://postimg.cc/8jkRMn3R [/IMG]
(In reality the 4 seems to be the dominant number but not on this picture.)
Old Yesterday, 06:26 AM
proporsche's Avatar
let`s see the numbers in picture..not to worry about the rest numbers just show it all between the stars and the engine case bottom 930/25
I would to a different person more knowledgeable than the one you went to...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old Yesterday, 06:42 AM
exam
The fact is the car already been to an exam place and they told me that given it has been tempered with they do not want to take on the risk of passing it.
They fear that the overstamp is because som shady thing and they pass it it can be a legal issue.
Old Yesterday, 06:49 AM
proporsche's Avatar
looks from the picture the 3 is original unumber....
Ivan
Old Yesterday, 10:28 AM
Jeff Alton's Avatar
IF its a "63K" it an 89 3.2 (170KW) if it is a "64K" it is 89 3.2 with a catalytic converter (160KW).
So the "63" were euro/ROW and the "64" were North American. That is just from a quick search of our library.
Cheers
www.turn3autosport.com
Old Yesterday, 08:07 PM
Thank you guys.
The problem is not the fact is was originally designed for US or ROW.
The issue is it doesn't have a COA since its not original in the car (car is '87 motor is '89). If not documented properly, in Hungary it cannot pass the exam for license plate. For us a COA or proper papers for the motor change is obligatory. The reason it was discovered was the number issue, but this is also why it is harder to get papers for it.
I think what would be nice to know if the numbers after the letter lets say 6*K02222 are unique numbers in the K year or did they count the regional motors differently?
Were a 63K02222 and 64K02222 produced or just one depending on the original destination country? If both exists I think I will have a really hard time getting any certificate even from porsche itself since I dont know which one I have. (CAT and a slight difference in compression wouldn't tell the story since they could be altered later) Basically as far as I know the motor block itsel fis identical and the difference is only in the assembly as the whole ICE/ unit.
Old Today, 12:32 AM
proporsche's Avatar
what is the number 930/ ??
the rest of the 5 numbers is just serial number....
it is strange as you say ,the car was driving registered in Hungary past 10 years and you need extra documentations?
i`d go to a different place with the 911..
Ivan
Old Today, 02:53 AM
djpateman's Avatar
63K00001 930/20
64K00001 930/25 with cat
so you need to look for the 930/2x stamp nearby to determine the correct engine type, and thus the correct serial #. Both series are independent, so the same serial will exist in 63K and 64K, but only one will match the 930/2x. If the 930/2x has also been tampered with then that is just more trouble.
What if you were to get a blank replacement case and rebuild the engine on that? How do the inspection authorities treat a case without numbers?
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old Today, 04:01 AM
proporsche's Avatar
Originally Posted by djpateman View Post
63K00001 930/20
DJ...I was hoping you will show up....yup ,keep asking him for that 930/.. number
Still wierd the car was driving in Hungary for 10 years
kristof it is here....in black cirle
Old Today, 05:10 AM
Tags
motor number , motor serial
