My right rear caliper is binding on the rotor. Pads are worn down pretty far. Think new pads will keep them from binding? New calipers? Rebiuld? I would think with the new pads, it would push the pistons back in where they would'nt bind? Seemed to work on an old 914 before. (Don't be a 914 hater) By the way, it's a 81' 911 SC.
Please help, Troy |
I would think rebuild the calipers and put new pads in and you should be fine.
Ya know, I don't have any fluid leaking out. I know that is a true sign of a rebuild. But, it does bind? Steve, you are probably right. I will just have to rebuild them. Thanks for the reply.
Troy 72' 911 T 97' Boxster 81' SC coupe / sold 76' slant nose 81' SC Targa / sold 77' s / sold 67' 912 / sold 89' 944 / sold 74' 914 / sold 71' 914 / sold |
Somatic Negative Optimist
Excercise your pistons. Take the wheel off, pry the old pads back with channel lock pliers, pump the pedal so that the pistons come back out. repeat 3-4 times. By moving the pads/pistons with the pliers, you can feel if there is any binding. Usually, after 3-4 moves, the pistons feel smooth again. If not, check the tech articles and rebuild. Keep the old pads. I sometimes take pads out that are still good, then use the really worn pads to "excercise" the pistons, then put the good pads back in. With the old pads, I get maximum travel. I also open the bleeder nippels just enough to see a few drops of fluid come out in case there is some air trapped. Measure your rotors for the minimum thickness: ~19mm front, 18.6mm rear, and check for play in the bearings. Cheers.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
