Trust Me's Avatar
Question Binding brake caliper
My right rear caliper is binding on the rotor. Pads are worn down pretty far. Think new pads will keep them from binding? New calipers? Rebiuld? I would think with the new pads, it would push the pistons back in where they would'nt bind? Seemed to work on an old 914 before. (Don't be a 914 hater) By the way, it's a 81' 911 SC.
Please help, Troy
Old 07-13-2003, 02:49 PM
I would think rebuild the calipers and put new pads in and you should be fine.
Old 07-13-2003, 03:01 PM
Trust Me's Avatar
Ya know, I don't have any fluid leaking out. I know that is a true sign of a rebuild. But, it does bind? Steve, you are probably right. I will just have to rebuild them. Thanks for the reply.
Troy
72' 911 T
97' Boxster
81' SC coupe / sold
76' slant nose
81' SC Targa / sold
77' s / sold
67' 912 / sold
89' 944 / sold
74' 914 / sold
71' 914 / sold
Old 07-13-2003, 05:39 PM
Somatic Negative Optimist
Gunter's Avatar
Excercise your pistons. Take the wheel off, pry the old pads back with channel lock pliers, pump the pedal so that the pistons come back out. repeat 3-4 times. By moving the pads/pistons with the pliers, you can feel if there is any binding. Usually, after 3-4 moves, the pistons feel smooth again. If not, check the tech articles and rebuild. Keep the old pads. I sometimes take pads out that are still good, then use the really worn pads to "excercise" the pistons, then put the good pads back in. With the old pads, I get maximum travel. I also open the bleeder nippels just enough to see a few drops of fluid come out in case there is some air trapped. Measure your rotors for the minimum thickness: ~19mm front, 18.6mm rear, and check for play in the bearings. Cheers.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 07-13-2003, 06:08 PM
