Simple Green and 409: Don't Use
Aviation Consumer magazine just did a test of various cleaners specifically manufactured for aircraft exteriors, and in a sidebar, they published the results of their testing of Simple Green and 409, common and widely used cleaners that I suspect some of us have sprayed on our engines at one time or another.
Bad idea. Because most aircraft are virtually all aluminum (like our engines), corrosion was a major concern of the AC testers, who did both lab and real-world testing of Simple Green and 409 and found substantial, measurable corrosion in as little as 48 hours. 409 was measurably worse than SImple Green. Indeed, the company that makes Simple Green _said_ to AC that it shouldn't be used around aluminum (which I assume it says on the bottle). The lesson seems to be that if you buy any kind of degreaser/cleaner, make sure it has corrosion inhibitors and/or has no effect on aluminum. (I use P21S Total Auto Wash, which despite a name that makes it sound like it should be used for ordinary washjobs is in fact a powerful degreaser.) Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
I've used the citrus based cleaners with no ill effects after thorough rinsing with water (for underside of engine - not polished rims)
Mike - PBG, FL '14 958 Cayenne GTS '05 997 C2 - SOLD '79 911 SC Widebody PCA, NASA, PBOC - SOLD 2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3 |
I've used ZEP brand citrus degreaser, works and smells good to. I wonder what it would taste like with a little vodka?
John Adams 1980 ROW 911SC |
At my work ( California Fire Department), we recieved a memoradum about a year ago, ordering us to stop using Simple Green to clean our helicopters. We use to use it every day to remove the bugs and grease on the rotor mast and underbelly. The memoraum stated the same thing that Stephan quoted.
I've used Simple Green on my engines for 20 years. Enough said.
In the shop at Pelican
I've used Simple Green to clean engines for years and have never had a problem as well..
works good on my floor.
Super Moderator
Works great on garage clothes too.
But I had also heard similar comments on the effects on bare aluminum some 10 years ago...
The bottle does say not to use it on Aluminum...
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
What the hell is in Simple Green anyway?
Senior Member
It is The Business on Amal and Bing carbs (motorbikes). Anyone who has had to restore old bike carbs does the spray and clean using SGreen just because it *does* attack alum.
John
'78 Targa in Minerva Blue |
I can remember using 409 or Fantastik on glass one time....and did not get all of it off it time..and it etched the glass.
It turned white in runny configuration where it was sprayed on and dripped downwards. Bob
Bob Hutson |
I used it on some of my bike parts made by Campagnola. Never again. It striped the polished anodized surface off.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
I happen to work for one of the companies that makes a citrus Degreaser/Cleaner. Citrus oils contain a natural solvent that cuts grease very well.
It's not that the Simple Green (or other citrus product) causes the corrossion it is that it does a good job of removing the grease allowing the aluminum to corrode. Prevention: Rinse very well and then drive getting the car/engine up to a good high temperature.
Fritz 1987 944S 1973 911E |
I've been using a diluted mixture on Simple Green on my Fikse FM-10s. Not any more. Thanks' for the tip. Even though no problems have arisen, I don't want to chance it.
So what was the magazine's preferred cleaner? or cleaners?
