-   -   911 engine codes (http://forums.pelicanparts.com/porsche-911-technical-forum/121529-911-engine-codes.html)
djpateman 03-18-2021 05:41 PM
If an engine case has been replaced, then automatically it is no longer numbers matching.
If an engine has had work do, especially a full engine rebuild, then take nothing as given. For this car you will need several engine photos, and get part #'s off of the major components. Example, the MFI injection pump has a few numbers, all of which are important. The more the car deviates from original, the lesser the value. You really need someone with the expertise to evaluate the car properly.
kenpro42 07-11-2021 09:26 AM
I would appreciate it if someone can help-> I have a 1976 911 vin# 911 630 1689 with engine number 6373208 - 911/81. I'm not sure if the '76 engine has been replaced with a '77 and not sure why the technical spec book states "Starting with 2001 = engine type 930/54 (Turbo model 1977 Japan)
djpateman 07-12-2021 07:22 AM
9116301689 is a 1976 911 for ROW (that is not for North America).
6373208 is 911/81 for 1977 ROW
The date mismatch definitely means the original engine has been replaced. I can find the original engine #.
I don't have the Turbo serial ranges at hand, but that appears to be a split serial range.
MarkWard 11-01-2021 09:58 AM
1980 911
Hello, new to the forum. Reviving a thread. Have a new to me 1980 911. It was represented as a Euro car. It has broken head studs and I'm researching what engine and specifically the cam timing adjustment. My Bentley does not seem to cover these engine numbers. Vertically the number is 6300987. The number in the horizontal casting is 930/09. Any information including where to find the actual specs would be appreciated. I hope posting to this thread vs starting a new thread is proper. Thank you in advance. Mark
http://forums.pelicanparts.com/uploa...1635785760.jpg
http://forums.pelicanparts.com/uploa...1635785830.jpg
JJ 911SC 11-03-2021 02:44 AM
From the Red book (not always 100% accurate):
1980 911SC, Rest of World version
Engine #: 6300001 to 6304831
Matching Chassis Serial #: 91AO130001 to 91AO134831. The 3 is for RoW.
8.6:1 compression ratio
188 hp @ 5,500 RPM
188 f-p torque @ 4,200
Matching Transmissions: Type 915/62 (5 speed)
Dave (djpateman) might have more info.
MarkWard 11-03-2021 05:38 AM
Thank you. My post had to be approved, so in the mean time I found the cam timing in Bruce Anderson’s book. Height of overlap at TDC is 1.4 to 1.7 mm for the 78 to 80 ROW SC. Plan is to measure prior to tear down. Thanks again. Mark
Bill Douglas 11-03-2021 07:09 PM
This site is very good for chassis numbers engine models and numbers. Simon's Porsche 911 SC Site
MarkWard 11-04-2021 01:08 PM
Bookmarked, thank you.
speedracer07 11-08-2021 09:50 PM
964 Motor
I have a 964/3.6L motor I bough years ago from this guy that past away shortly after , not sure what year it is,89 or 90.
Here are the #s Vertical * six two L five one five four one* Type M 6A/02
Thanks for your help!
JJ 911SC 11-09-2021 02:55 AM
Originally Posted by speedracer07 (Post 11513445)
I... Here are the #s Vertical * six two L five one five four one* Type M 6A/02
90, M64/02 fitted to Carrera 2 with Tiptronic
2mAn 05-21-2022 08:44 PM
Rather than start a new thread I figured I would bump this one...
Found a 'long-block' and am getting conflicting info from the seller. Did plenty of searching and found this little breakdown
Originally Posted by former Pelican Poster
Your 7=digit ’75 engine number should have the form:
*6X5xxxx*
where:
6 = Engine design, 6-cylinder engine
X = numbers 1-7 (see list below)
5 = Model year 1975
X = 1, 911, Type 911/41, (or Type 911/46 for Sportomatic)
X = 3, 911S, Type 911/42, (or Type 911/47 for Sportomatic)
X = 4, 911S/Carrera USA, Type 911/43, (or Type 911/48 for Sportomatic)
X = 5, 911S/Carrera California, Type 911/44, (or Type 911/49 for Sportomatic)
X = 6, Carrera 2.7 (MFI), Type 911/83
X = 7, Turbo 3.0, Type 930/50
Im a little confused because this one starts with a 640 ####
So is this a 1980 3.0 SC motor or a 1970 ...2.2 or something?
Case has 901.105.111.0R & 901.101.101.3R ...
Can anyone clarify this for me? I thought the 3.0 would've been a 930 on the case, not 901
Be kind, I've been a dreamer for too long and am finally trying to start collecting pieces to start building
djpateman 05-26-2022 05:40 PM
a 640xxxx serial with a 101.3R case half should be a 1970 2.0 914/6 engine case.
2mAn 05-30-2022 11:04 AM
Thanks! A 914-6 is missing its engine!
Coastr 05-31-2022 03:03 AM
Originally Posted by carycole (Post 11264544)
I believe it is a MFI. I do know that it was imported from Germany in the 1980's. Wouldn't that make it a MFI?
An old question but 3.0 Carreras are CIS. MFI Carreras are 2.7, and they finished in 1976
tonyduc 07-15-2022 10:20 AM
I’ve seen several posts regarding decoding a 1977 911S. My engine code is 6271204: research shows that ‘2’ means a U.S. model. Question I have is 2 for all 50 states or 49 (minus CA)? I ask because with respect to timing the owners manual gives one setting for US and another for CA. The gold tag on the engine fan housing only gives a setting 15 ATDC (which happens to be CA). Only reason I can think of is that by 77 all engines conform to CA ? Also the car has a stamp saying non-catalytic car. Any help is much appreciated!
Tony
rajsekhon 10-24-2023 06:19 AM
Experts, I am new to this thread, Need help on my engine Stamp on my ROW. (Japan, imported via the UK)
The car is an 78 SC RS/R Homage,
the engine stamp on fan support states:
930/25
No stars that I can see: 6181993
also there is some stamp on the under site near the oil pile:
J6/911.107.041.00
stamp under the engine stated 830 101 104 5R
I am not sure if the engine was replaced in Japan or the UK
see photos
I have a letter of ORIGIN for the VIN 9118309552 from Porsche UK, that states original engine was 6180055 and gearbox 7180855. Both engine and gearbox replaced with 3.2 and G50. Car was originally Red now Black.
I have plenty of history on the car from the service book but its all in Japanese going back to 1978. would like more info on the replacement Engine and Gearbox.
Thanks again
attached some photos
http://forums.pelicanparts.com/uploa...1698153309.jpg
rajsekhon 10-24-2023 06:24 AM
More images:
http://forums.pelicanparts.com/uploa...1698153800.jpg
rajsekhon 10-24-2023 06:29 AM
http://forums.pelicanparts.com/uploa...1698154182.JPG
maddin 03-30-2025 07:15 PM
Hi there,hope somebody can help.
trying to figure out the engine number here,looks like a 5 to me but surely it has to be a 6?
6180002
930 101 103 OR
supposedly a 76/77 3.0l Carrera Japan
thanks for your help! Much appreciated
http://forums.pelicanparts.com/uploa...1743387140.jpg
JJ 911SC 04-01-2025 04:59 PM
Engine 6180002 (930/05, 2 of 304) was fitted in a 1978 Japan 911SC.
The chassis serial # should be between 9118309501 and 9118309804 (911 SC RoW)
Of note, there is no Porsche engine serial number that start with a "5"
