-   -   911 engine codes (http://forums.pelicanparts.com/porsche-911-technical-forum/121529-911-engine-codes.html)
maddin 04-01-2025 11:08 PM
Originally Posted by JJ 911SC (Post 12439217)
Engine 6180002 (930/05, 2 of 304) was fitted in a 1978 Japan 911SC.
The chassis serial # should be between 9118309501 and 9118309804 (911 SC RoW)
Of note, there is no Porsche engine serial number that start with a "5"
Excellent thank you!
The engine is in my 914...
just to confirm..it's not a Carrera? My mechanic said it has the larger inlet ports...
thanks again!
frayedknot 07-17-2025 10:00 AM
Considering buying this car
Vin: 9119301765 - Decodes as 1979 911SC RoW Coupe
Engine: 6401565 - This doesnt show up in any database I have found.
Help?
frayedknot 07-17-2025 10:09 AM
Help?
Nevermind. Found it on Porsches PET manuals
911 SC (USA)(CDN) 930.07 80 A 640 0001>9999 6-ZYL/3,0L/132KW
djpateman 07-17-2025 04:20 PM
You need to search better databases.
640xxxx could be a 1970 914/6 or a 1980 911SC. Fortunately for you 1565 falls in a dead zone for the 914/6 so that eliminates it. But a 1980 engine in a 1979 car is a cause of concern and value.
