Hi guys, trying to buy a 1970 911T Karmann coupe and trying to figure out if the numbers are matching.
Chassis 911 0122050 Engine 6106947 Trans 91100 700 421 |
Yes, the engine # is a very good match to the VIN. The transmission # is missing a digit (should be 7), and I think would be 7000421. I do not have much data linking VIN's to transmission #'s and the 4 speed (type 911/00 serial 7000001 to 7000691) data is almost non-existent, however, the serial is not inconsistent with the VIN.
BTW, if the Redbook says that a Karmann chassis can only have a 911/08 engine, then the book is less than useless. They only made 227 911/08 engines and there were 4116 Karmann 911T. |
Any one still around to help decode this 1977 Targa engine?
6273837 |
911.85 2,7L 6 1977 Porsche 911S (USA)(CDN) (121Kw / 166Hp) 6270001 >>
Here is a link to the site with the info:Porsche Engine Code Resource |
'71 T Back To Life
The numbers for our '71T Coupe:
VIN: 9111100732 Engine: 6115580 Type: 911/07 Transaxle: 7114096 Ratios: 911/01 = A-GA-0-V-ZA Date Code: 901.301.101.OR This one has me stumped to find out how to decipher. Any help here is appreciated. Our first LWB car and looking forward to putting it back on the road after a 15 year sleep. Thanks! http://forums.pelicanparts.com/uploa...1519251936.jpg |
* 6590600 * any ideas
Can someone help me with identifying an engine please? I have a 72 Targa which came into the UK from South Africa. I was aware that it wasn't matching numbers when I bought it. Its running on Zeniths and pulls very well. I pulled the motor out to have the gearbox rebuilt so decided to put a clutch in it and fix the normal oil leaks. Anyway it is running alloy heads dated 1/70 - iron cylinders (no idea of age). I was told it was a 2.7 and is registered in the UK as a 2.7. There is no type number in the usual place. There are 2 engine numbers (both the same) - one on the fan tower and one at the rear next to the breather (was concerned that it was a 914 motor when I saw this) - number is 6025445. Understand the 6 is for number of cylinders ( check lol) and the 2 is for 1972. The type number 0 is confusing - any ideas?
Its definitely 0 JJ - I have checked and re-checked.
To confuse matters more both numbers actually start with a D |
Is there a * (star) stamped before and after the engine number? |
no there are no stars
there is no type number in the usual place either so agree that likely a replacement case
Well, the car serial number (10 digits) could tell you if it was for the US market or not.
its a South African car imported recently to the UK
Could you guys offer me any help on what the 6451413* engine number means? It is in a 1975S which I think is the right model year for this number.
6451413 is type 911/43 for a 1975 911S US market car
can you PM me the VIN please |
Hello guys i have an 81 sc new to me #s as follows *6411168* and 930/16 any info would be great as I know nothing
thank Paul |
6411168 is type 930/16 for a 1981 911SC US market car 180HP@5500rpm
| All times are GMT -8. The time now is 04:07 AM. |
