"Euro" engine
Hi Guys, new to the forum and looking for some help in a 3.2 engine upgrade for my '83 SC. I'm looking at an engine being sold as and 1987 3.2 Euro. Just trying to confirm. Any help would be greatly appreciated.
number is *63G10282* http://forums.pelicanparts.com/uploa...1304183603.jpg Thanks in advance for any info. |
63G means '86 930/20.
Thanks PeterRT. Forgive my ignorance but what does that mean specifically? Although I've owned a 911 since I was eighteen(more than 20 years) this is my first engine swap so I've not had to educate myself in this area so far. Now if you want to know any thing about replacing the engine in a Hummer H1...or heater core...or cracked rotors...or, well ask me anything.
Sorry. The /20 means it's the catless, high compression, 228 bhp version of the 3.2. So it's indeed a RoW/Euro engine. The #s of cat engines (/21, /25) start with 64... The letter in 3rd position shows the model year. G='86, H='87, J='88, etc.
Thanks so much. That's a big help. I'll post how things turn out.
Does anyone know if engine no. 3380822 is the correct match for a 68 911 coupe USA equipped with a Sporto? What do the numbers denote in this instance?
Yes, the 338xxxx series is 1968 911L sporto equipped.
However 0822 is too high for the series; 3380464 was the highest built AFAIK. Please check the number, and if possible email the photo to me. Also check to see the type # and the build #: Type 901/xx Engine Build #'s |
The eight in the 0822 sequence originally appears to have been a three that was altered. I'll post a photo ASAP.
The build # will help me determine the truth.
http://forums.pelicanparts.com/uploa...1305737637.jpg |
It appears to be a 3 over the 8; the 3 appears clearer in parts. That is not so bad because the fonts of the 3's & 8's appear to be consistent; therefore I suspect a factory typo as opposed to fraud. The build # will help for sure.
Here it is: 901/17 14383
901/17 3380150 12116
901/17 3380223 13016 901/17 3380303 14124 901/17 3380322 14383 901/17 3380373 15815 901/17 3380402 16015 I would say that it fits well. |
Hi everyone,
wondering if you can help me to find out the spec of my engine: Engine No: (star) 64H06771 (star) 930/25 What I know based on the forum is that is a CAT engine from 1987... Thanks in advance. |
1987-89 Carrera USA spec 3.2l, bore stroke: 95x74.4, 3164cc, Valves: 49 Intake & 41.5 exhaust Ports: Intake 40, exhaust 38, 9.5:1 cr 217hp @ 5900 rpm and 195lb/ft @ 4800 rpm Hope that helps! SmileWavy |
Hi all,
I too have a couple numbers for you, i don't have the engine type number here with me at work though. Vin: 9116301498 Eng #: 6362248 |
I as well have an Numbers question since I am very new to this..
I looked at the thread to find where to acquire the numbers and this is what I came up with *6106191* 911/07 I know the engine isn't original to the car as it is currently in a 912 any help would be appreciated |
Engine: Type 911/81, Japan/RoW spec 2.7L, CIS fuel injection, 165hp@5800 rpm / 176ft lb trq@4000 rpm, bore90/stroke 70.4, 8.5:1 cr, 46mm intake & 40 exhaust valves, ports Int 35MM / exh 35MM. #2248 of production run Hope this helpsSmileWavy |
USA spec 2.2L / 2195cc, Zenith 40 TIN carbs, 125hp@5800rpm & 130ftlb trq@ 4200 rpm, bore: 84 / stroke: 66, 8.6:1 cr, Int valve 46mm & Exh 40mm, ports Int 32 / exh 32mm, from production # 610 5001 - 611 4001 Hope this helps SmileWavy |
901/17 USA spec 2.0 L (1991cc), 130hp@6100 rpm, 175 tq@4200 rpm, bore/stroke 80/66, 9.0:1cr, Valves Int/Ex 39/35, Ports Int/Ex 32/32, Weber 40 IDAP, Serial# 338 001+ (as detailed earlier by djpateman) Nice old skool Hot Rod 2litre! |
| All times are GMT -8. The time now is 10:49 PM. |
