-   -   911 engine codes (http://forums.pelicanparts.com/porsche-911-technical-forum/121529-911-engine-codes.html)
Charles Freeborn 07-23-2011 05:33 PM
I too spun the serial # roulette wheel hoping to find my 74 has a rare RS or some such engine... but alas no, just your (or mine) garden variety S engine # 6341146....
ASHSEIDL 07-30-2011 11:54 AM
I have a couple engines i cannot find info on.
Both were on a 914 that my grandfather has turned into a legit 914/6.
I want to see if the engine # 980/10 is a 911 engine or a actual 914/6
the other number is on a 2 L # 3A000811
Can anyone help?
AshMan
1973 914/6
1987 944
1976 935
djpateman 07-31-2011 09:20 AM
the 980/10 is probably 930/10 a 911 SC 3L motor
3A000811 may be GA000811 a 1973 914/4 2L engine
Driver_X 08-10-2011 06:00 PM
Finally got around to checking the motor in my '74. Looks like it might be the original one, no? At the very least a '74 motor correct?
VIN: 9114102131
Engine #:6143423
djpateman 08-11-2011 08:50 AM
Driver_X, yes that could be original.
asparp 08-25-2011 10:58 AM
VIn codes and engines 911 1970
Hi,
I am new in this forum as I am about to buy a old 911 apparently from 1970. that would be my first one, so i have a lot of doubt, furthermore because here in mexico it is hard to find parts , or someone to fix it...:(
The owner told me that it was a 1970 with a 1975 body kit and a 2.4L engine (with Weber carbs), but i would like to check with you before buying it:
The numbers I got are:
Chassis: 9110101976
Engine (vertical number on the side of the blower): 610 95 11
Number on the top of the blower: 901 106 101 5R
Other thing, the bodywork is in great shape, the gear box is manual five, with the first gear on the bottom left apparently and then 2,3,4, 5 in H. Direction has no play, it seems to have bleinstein suspension....
The block is leaking a little bit (it's greasy underneath, and I could see some little oil on the ground) but the car is park there since a while so I don't know what to think...
What is average price of such 911?
Thanks in advance.:)http://forums.pelicanparts.com/uploa...1314295068.jpg
asparp 08-25-2011 11:00 AM
this is the enginehttp://forums.pelicanparts.com/uploa...1314295218.jpg
911Freak 08-25-2011 12:13 PM
Originally Posted by asparp (Post 6217586)
Hi,
Chassis: 9110101976
That is a 1970 911T engine 911/08, 2.2L, zenith 40 carbs, 125 hp
That is a 901 gear box, the predecessor to the 915
The VIN# shows a 1970 911T, coupe
9110101976=
911 = 911
0 = 1970
1 = 911T
0 = coupe
1976 = sequential serial number
I can't tell if that's the original engine to the chassis but it sure is all 1970 gear so it is possible, a COA from PCNA would solve that.
Value? If the modifications can be reversed then it helps somewhat..
But they did an update from a valuable original 1970 911 to the least desirable model mid year (1974-1977) 911, so that hurts the value for sure.
If it was an original unmolested 1970 911T it would be worth more
I would be most concerned with any rust in the usual places: front suspension pan, lower front windshield areas, rockers, door striker panels, floors, drivers pedal area, rear window to quarter panel areas etc etc etc...
I'd be taking pictures of these areas and poking around looking for bondo/shoddy repairs and rust.
Just for starters the pic of that engine shows it has not been updated with the newer chain tensioners and has the usual leaks coming from the oil breather and oil sender light aka unholy trinity. You will want to do a compression check and leak-down check especially if it hasn't been run in a while. Lots of threads on this here, do some research and see where you need to start before dropping any cash, this could be a very expensive venture, or if you can buy it for a song you might break even....
Be careful and post up a new thread in the 911 Tech section with your findings. You'll get more feedback that way as well...
911Freak 08-25-2011 12:17 PM
VIN: 9114102131
Engine #:6143423
1974, base 911 (not an S or Carrera) coupe,
engine is 1974, base 911/92, 150hp, 2.7L, CIS
Driver_X 08-25-2011 01:29 PM
Yup, that's what I got....
HkPlinker 08-30-2011 06:36 PM
Ok, guys. Here goes my turn.
*911790*
901/06
8665
Thank you all.
911Freak 08-30-2011 07:36 PM
Well......
901/06 shows up in '67 and '68 however, '68 would be a 308xxxx and not a 911xxx, so that indicates this 901/06 is, in fact a 1967 911 2.0L.
Engine serial # 911 001+
911 790 (790th in production)
901/06:
1991cc/2.0L, 130hp, 128tq, Bore/stroke 80/66, 9.0:1cr, Valves int/ex 39/35, Ports Int/ex 32/32, Weber 40IDA, first year for updated/revised heat exchangers
Nice early 2ltr! Have any pics? Where is the 911 that goes along with this sweet little engine?
Aussie Thunder 08-30-2011 08:11 PM
Could someone please decode this one for me ..
Sry about the picture Quality - very tight in there and was shooting blind !!
Number reads 61L53650
Thanks !!
Ta ..http://forums.pelicanparts.com/uploa...1314760158.jpg
Aussie Thunder 08-30-2011 08:15 PM
This is what the Intercooler looks like for the above post -
http://forums.pelicanparts.com/uploa...1314760532.jpg
911Freak 08-31-2011 12:09 AM
Thanks !!
I take it this is for your 1989 930?
That engine # is from a late 89 possibly early 90 3.3T motor.
My books go up to '89MY engine#930/68 = 68Kxxxxx. So knowing Porsche I suspect engine build designates J (88 Turbo) , K (89 Turbo) then L would be the next logical designator (late 89 or 90?)...
Sorry can't be more help :confused: I am sure eventually someone will chime in, you might want to post this question with your #'s and pics in the 930 Turbo Forum:
911 / 930 Turbo & Super Charging Forum - Pelican Parts Technical BBS
FYI
1989 R.o.W 911Turbo, 930/66, 3299cc, 300hp@5500 rpm (US/Canada 282hp), 430ft lb@4000 rpm (US/Canada 390ft lb), Bore/stroke 97/74.4, 7.0:1 cr, Valves Int/ex 49/41.5, Ports Int/ex 32/34, Euro CIS Fuel Injection :eek::eek::eek:
Cheers
Jason
Aussie Thunder 08-31-2011 04:43 AM
Thanks Jason, when I bought the car I was told it had a 965 motor .. Last time it was serviced the mechanic (porsche race car driver and race car builder for 20+ years) Estimated HP at high 400's low 500's - I know only a dyno will tell us this but it was interesting to me as it must have some serious mods that I'm unaware of as it's new owner ..
HkPlinker 08-31-2011 05:36 AM
Freak,
I bought this engine with a very original 1976 (yes, 76) 911 S Targa. The original 1976 MAG cast block was cracked so, Stephen Kaspar (Kansas City) sourced this 67 block and machined the 2.0L The spigots and some other few changes made to accept the 2.7 JE pistons and cylinders as well as the crank, oil fed chain tensioners, oil pump and new bearings. The intermediate shaft was also modified and an updated intermediate shaft gear cut, new rockers arms, elephant teeth, etc . .
Updated SC cams were used as well as a 1967 distributor was also used to keep the "old school" look. The entire fuel system was replaced as well. The exhaust consist of headers to SSI stainless pipes. It sounds fantastic and pulls all the way to 7,000rpm. The motor costs as much as the car did, but I am completely thrilled with the outcome. It dyno'd at 225 hp and 212lbs torque.
On an interesting note, Stephen also custom built a four wheel Bilsten coil overs set up for this car and lowered to euro ride height. It drives smoother than my 1988 Turbo. It has been a dream to drive these past few years.
I added the Carrera script, the duck and chin spoiler to make the car look like it sounds. I have the original Mag block and trunk lid. http://forums.pelicanparts.com/uploa...1314793305.jpg
http://forums.pelicanparts.com/uploa...1314793352.jpg
mpmorris 09-03-2011 12:59 PM
EARLY 911 engine ID
Hello All.
I just purchased a thoroughly trashed '74 Targa that came with a spare engine -I've read all the replies herein posted and still haven't figured out what I have. This engine has two mechanical fuel pumps bolted to it and the air box is a different configuration than your standard solex/weber/zenith -but definetly original. No idea where the original car is.
The vertical # is: 903622; the horizontal # is: 901/01..3523
Any help here?
mpmorris
Grady Clay 09-03-2011 01:14 PM
mpmorris,
You have an early Solex 911 from 1965, the ~3622th one built.
It is very desirable to keep this entire engine together and find an appropriate early 911 for it.
EDIT
Welcome to the Pelican Forum. SmileWavy
You will find a lot of help here.
Start another thread showing your ‘find’ Targa, extra engine and more.
We can help you make proper decisions with the ’74 so you don’t go somewhere you don’t want to go.
The ’65 engine is a great ‘find’ in its own right. :cool:
You found the right place to post.
Welcome again.
Best,
Grady
mpmorris 09-03-2011 02:11 PM
Thanks for the Welcome Grady, and thanks for identifying the '65 engine. The '74 will sit until I decide a path as it does need everything -runs but sounds like the heads are falling off -you can hear the compression blowing out. The body is banged up, the interior is shot -just very sad all around -I'm sure if I start poking around I'll find a rust cavity somewhere.
thanks again -SmileWavy
mpmorris
