-   -   911 engine codes (http://forums.pelicanparts.com/porsche-911-technical-forum/121529-911-engine-codes.html)
20C4S 09-11-2014 09:58 AM
Originally Posted by djpateman (Post 8256662)
6551097 type 911/44 911S US Calif. one of about 1800
6195387 type 901/16 as JJ says, under the type # is a build # probably in the 18xxx range; can you tell me the exact # please.
djpateman & JJ,
thank you. i'll see if i can get the #. where do i look for?
on the 6551097, so i assume it's indeed a pretty rare gem?
JJ 911SC 09-11-2014 04:07 PM
So much easier to find when one give you the type :):D:)
http://forums.pelicanparts.com/uploa...1410476768.jpg
http://forums.pelicanparts.com/uploa...1410476795.jpg
djpateman 09-11-2014 04:48 PM
Not really rare with 1800 made. Designed just for California, and included the dreaded thermal reactors. This was the type of engine that gave the 2.7 a bad name. Significantly less power than it's siblings. It is an S engine, so don't let the Carrera installation fool you; those Carrera's were just a 911S with lipstick. Definitely not an engine to pay a premium for.
hakankuy 10-25-2014 10:24 AM
Hi there friends,
Porsche brand is very far away from me however I bot a 1968 911S coupe.
It has 3,2 liter 1986 engine on it.
Its chassis number is 118302XX
where engine number is 3280374. Does this engine number belong to its original 2,0 liter or the new one on it?
Thanks for your help
Hakan
JJ 911SC 10-25-2014 04:27 PM
1968 Range:
911 Coupe (US):
Chassis: 11830001-11830473
Engine: 3280001-3281606 (901/14)
473 Produced, so the chassis number & engine number you supply match.
A 3.2 engine numBer start with 62, 63, 64, 67 or 68, flowed by E, F, G, H, J or K
hakankuy 10-26-2014 12:05 PM
Originally Posted by JJ 911SC (Post 8323916)
1968 Range:
911 Coupe (US):
Thank you for your help.
timmy2 10-30-2014 02:13 PM
Sure it isn't a 930/03
The serial number is for a '78
According to this site.
http://www.adelgigs.com/911scproductiondata.shtml
Mikla 11-03-2014 12:34 PM
Hi all,
I am researching a pretty interesting case of a potential acquisition. It is a 1966 Karmann 911 with a 2.4 engine. After a deep research, we have found what seems to be the original block and the rest of the engine parts. The serial number does not match anything I have read: 5080016. The engine type number is not there (I still haven't seen it live, but the person who has it cannot find it). The other number that is clear is the block part number 901.101.101.3R
Can anyone give me a clue?
Thanks!
GregOrgy 01-12-2015 03:31 AM
Hello,
I see soem people can say if an engine is matching?
2 questions, where do you get this information? Online?
And can somebody tell me if I have the right engine:
It is a 1971 911E Targa
Vin: 9111210839
Engine: 6218232
Thanks!!
ossiblue 01-12-2015 07:27 AM
Originally Posted by GregOrgy (Post 8435834)
Hello,
Vin: 9111210839
Engine: 6218232
Thanks!!
Actually, the only way to know if an engine matches a particular car is to have the cardex or COA from Porsche. The best one can do otherwise is to know if the engine numbers fall within the range of a particular vehicle and match the type of vehicle.
In you case, the vehicle VIN, 9111210839 matches the description of a 1971 911E Targa, number 839 produced.
The engine number, 6218232 matches to a 1971 E engine for a sportomatic (the 8 indicates a sportomatic engine), number 232 produced.
If your car is a sportomatic, then the engine and chassis are within the matching range. If your car is not a sportomatic and has not been converted, then the engine is not matching to your vehicle.
Here is an online site that can help: Fahrzeug-Identifizierung
sleeper911 01-27-2015 01:45 PM
hello, can you decode an engine number? 67D0510. Thanks, this is my first time on tis great site. Not sure about the D. It is a turbo. 85 maybe?
JJ 911SC 01-27-2015 03:03 PM
It is a Turbo type 930/66 fitted in a 1983 930
Your VIN should be in the range of:
WPOZZZ93ZDS000001-1015 for a RoW; or
WPOJAO93CDS050001-0065 for a Canadian Model
How about a pic or two of the car.
sleeper911 01-27-2015 03:03 PM
could you help me with engine # 67D0510. Thank you. Not sure about the D. 7 is for turbo I think? 6 for # of the cylinders. Thanks very much
sleeper911 01-27-2015 04:45 PM
thank you very much. It is a Canadian 84 Carrera, made into a turbo, with all the proper parts. I did not know what year the engine was, and now I do. Thanks! Conversion was done back in 85. I just bought it from my neighbour. I will get a photo posted. It is quite a sleeper. Black on black, with no turbo badge, but the whale tail. Pelican Parts does not seem to list 83 as having a turbo? Maybe only in Canada? Thanks again. The D means in the #
JJ 911SC 01-27-2015 05:06 PM
The D in the VIN # is for year 1983.
You cannot select a Turbo Model on Pelican but as you go through the parts for the 83 years model where there is a difference between 911 and the 930 Turbo there will be different part numbers, guess which one is more expensive.
There was 65 delivered 930 Turbo in Canada in 1983.
Post or PM me your VIN number from the Door Jam sticker.
sleeper911 01-27-2015 05:18 PM
WPOABO918ES121817. I need the oil line from the crossover to the thermostat. 930 107 743 15 is too short. -10 is too long. I wonder about 911 107 743 12? I ordered the -15, to a US address. I borrowed a -10. I guess I can try the 3rd choice. The local Aeroquip people can't find the 30mm by 1.5 threads to make me one. Pelican Parts is not able to help. Having a non matching engine and car might be causing this issue I suppose? Must go out for a bit now. Thanks very much
sleeper911 01-27-2015 05:25 PM
how do I get back to this conversation in the future? Still new to this site. Thanks again
JJ 911SC 01-27-2015 05:40 PM
Originally Posted by sleeper911 (Post 8459024)
WPOABO918ES121817...
The 8 should be a C, serial 1817 out of 2282 made. Around April/May of 84
If the conversion was done in 85, we are talking about an 84 car with an 83 engine. Sound like some Canuck wrote off the 930 within a couple of years.
Yes, conversion always have its chalenge when looking for part.
Bonne Chance.
JJ 911SC 01-27-2015 05:47 PM
Just look at the Tread that you started: Click on you handle name beside "Welcome sleeper911" upper right, click on the statistic tab, then select Find all threads started by sleeper911.
sleeper911 01-27-2015 06:21 PM
nice car you have. I enjoyed seeing the photos. It is a work of art!
