I'm 1000 miles away from the engines...I will have the family double check.
Thanks for the assist...it's greatly appreciated. |
6105367
911/07 early 1970 911T for North America 6533127 911/57 very late 1973 911T-V Euro carb engine |
One of the motors is complete, the other is just the long block, as I recall. They both turn over by hand. Waiting for specific details on which has what, etc. How do I go about finding a value for these things? |
Confused about engine number
Hi, Just inherited a 1976 911S Targa 5speed, car runs great (wonderful sound). I am confused about the engine number. The COA says the engine number should be 6560709 but the number on the block is 'star' 6274359. What do I have?
Thanks in advance for any help, Jim |
anyone? the VIN is 9116210727. Thanks
it should have been type 911/84 for 911S US Calif. |
Why is the engine number on the COA so much 'higher' then the engine number in the car, the engine in the car being 'newer' (a 1977 vs a 1976). Just trying to understand all this.
Thanks for your reply, Jim |
77 - 930 Engine Number help
One of my cars is a 1977, 930, engine number is 930/53. *6870348*. Can someone tell me more about this engine... VIN number is 9307800347.
Thank you. |
the engine numbers are coded: 6 = 6 cyl 911 engine 5, 2 are engine series numbers for particular years and related to the type #'s 6, 7 are the model years the last four digits are the serial # But you have to look up the tables of engine type #'s and serial #'s to fully understand them. You need to study to improve your Porsche education. |
Engine code
Gents well what a great forum of knowledge. So my question is engine number 901.105.111.or. Or this number 6532634. Have been offered I for my vw bus but need to know a little mor. Any help would be great!
6532634 is the engine serial for a 1973 911T Euro engine with Zenith carbs
http://forums.pelicanparts.com/porsche-911-technical-forum/573024-newbie-engine-question.html#post5649728 |
Hey guys, what is exactly meant by "matching numbers" I have a chance to get a 65 911 with a vin number of 301100, paint code 6411 and engine number *901197* with 53k miles. Currently the owner is out of town on vacation so I thought I do a little research in the meantime.
I was told that engine and tranny # matched, but upon my brief inspection I could no locate the tranny #, where is it located ? Thanks in advance, G. Franklin |
Thank you no carbs with this I found out so I gave it a miss looking at another this week so may ask again if that's ok?
Engine # 6380059
Hi i have a 1976 Porsche 911S Vin# 9116200690 Engine# 6380056. Is this engine from a 1978 3 litre Porsche 911?
Thank you |
6380056 is a very early 1978 type 930/03 3 liter for RoW, higher HP than the US engine.
Engine codes - Not Sure of
I have a few engine codes here from Early 911 and chassis numbers;
Chassis 9113110688 1973 911T Engine 6131739 (Think this is 2.4 T Engine) Chassis 11805023 No Engine Number on engine how do i find this out? And an engine i have on the ground 6201088 (Think this is1970 911 E Engine but not sure if its 2.0,2.2 or 2.4):confused: Thank you for your help! :D |
Chassis 9113110688 1973 911T Targa
Engine 6131739 2.4 T Engine, and probably original Chassis 11805023 911L for USA, and very early #23 No Engine Number on engine how do i find this out? Probably a replacement case; to find original # you will need to contact PCNA. And an engine i have on the ground 6201088 1970 911E engine originally a 2.2 |
is there a list of casting numbers and how to read them ?
Are you asking about the casting part #'s that are molded into the parts, or the serial & type #'s that are stamped when the engines are completed? I'm still building my lists in a computer file. There are many books with partial lists.
| All times are GMT -8. The time now is 11:33 AM. |
