bump
But tell us more about the 1967. Can you post a photo of the paint badge and the VIN stamped in the front trunk, or the aluminum badge attached to the front slam panel. They would help me determine what type engine your car should have. |
I suppose I should also see about selling the earlier 2 litre engine and continue to run the 2.2 engine while I search for a 2.0 that would align with my car. |
Yet another date check. Sorry.
6103156 I'm thinking 6cyl, 911, 1970,production #3156. Am I close? Will. |
1970 type 911/06 for ROW Sportomatic 911T serial range 6103001 to 6103230
so #156 out of 230; does it still have the Sporto parts? |
Thanks mate!
It is an engine &'box that is currently for sale locally here in Oz. Looks pretty intact & complete. Want me to enquire further for you?? Will Quote:
No, but thanks. I have the Sporto parts that I need.
Can someone post the chart to decode these sets of numbers so we can look the up on our own? Or is it one of those "I'd tell you, but then I'd have to kill you" secret formulas? : P
yes ;)
[QUOTE=swbstudios;7777578]Ok, here they are 901/05 and 3865
Horizontal number as stated earlier is 907029 also, VIN is 308135 any idea if this is my original engine? Thanks[/ Is swbstudios 2 litter the correct engine for my 66 #303098? Thank you! |
so would my engine only be correct for 1967 or later 66 as well? Thanks
901/05 907001 to 908185 were 1966 model year
901/05 909xxx was for the 1967 model year So 907029 is ideal for Feb 1966 through July 1966. |
Thank you!
Hi
Do not get too excited about the Red Book numbering system. It has errors, I found that it is copied or Red Book copied it from other books, that had errors too. I found my 1969E coupe engine in the book to be for a 69E Targa. But the Porsche Kardex shows my engine is correct to the VIN. I knew the red book was wrong because I bought the car from the original owner who never did anything to the engine.
There is no separation of engines by body type. Engines for the coupe and targa were pulled from the same pool of engines. While the engines were built in serial order, they were not installed in the same order. The chance of two consecutive VIN's getting engines in consecutive order are pretty slim. The same applies to transmission serial numbers.
vin # WPOAB0916HS121755
Engine code-64e04132 Any help what it is? Looking at a car that owner doesn't have any info. Pretty rough shape. Was told it's a 81 but I don't think so |
| All times are GMT -8. The time now is 11:13 AM. |
