Mine or speedos?
yours is a 69E engine .My mistake i tought you offering your engine to speedo
thanks
I would be totally ok....
....with someone offering me their 1970 6301329 engine.
That would in fact make my day. I would probably have to offer that person several cold beers :D plus $$ :) Speedo |
THANK YOU VERY MUCH for all the info!!!!!!!!! |
It is fitted with a Catalytic converters. There was an Option Code for California "M027" (see quote below). I doubt that the Air Filter would not pass but you never know. You should do a specific Post for it. Quote:
Thank you. I have the old airbox so that is one thing I won't need to find. The car was a CAlifronia spec SC from day one BUT it no longer has that CA approved 3.0. So Ca Smog Stations require me to prove the engine was originally out of a CA smoged car. Its a serious PITA. I am also required to put all the emissons equipment on the car for the year of the motor not the car. That won't be hard in case but I have got to find out if this 3.2 came out of a CA car. I will be calling Parts Heaven Monday afternoon to see what they can find out as the motor came from them. Tahnks again for all the help!!!!!
Engine
Hi,
I recently bought a '77 911S (VIN 9117200097). The engine casing (?) is marked 930/06. The engine crank casing in the bottom is 930 101 1034R...does that correspond to a 3 liter motor? If so, from what year is it from? Thank you! |
The 930/06 was fitted to a 78 Targa California. 3 liter fitted with with Catalytic Converters and EGR emissions. |
63S04494 would be?
The matching VIN would be WPOZZZ99ZSS314494 |
VIN 911 520 0604
engine 655043 Thanks in advance! |
655043 is missing at least one digit. Also look for the engine type # located to the right of, and behind the serial #.
Type of engine???
Hello,
I have a 1970 T 911 with engine code 6561436 looking for type of engine this is Thanx guys |
Engine type
Hi,
My engine number is 6580158. What type could it be? Thank you for your help! |
Thank you |
| All times are GMT -8. The time now is 05:21 PM. |
