LinkBack Thread Tools Rating: Thread Rating: 10 votes, 4.90 average.
fastspeed's Avatar
Question 911 engine codes
I bought a 911 engine,and i dont know wich model is,the engine
code is 961390,somebody can help me?
Regards Fastspeed.
Old 08-01-2003, 05:07 AM
Bandwidth AbUser
Jim Richards's Avatar
fastspeed, would you double check your engine number? It doesn't look right to me.
Jim R.
Old 08-01-2003, 06:35 AM
What do you mean by engine 'code' number ?
There are essentially 2 numbers which identify a 911 engine - both can be found to the right hand side of the fan assembly :
the engine serial number which from '69 - '81 was seven digits beginning with a 6 then from '82 - on it was 8 digits (as earlier but with a letter inserted after the first two digits) eg 62P12345
& the engine type number which will be in the format
901/xx
911/xx
930/xx or
M64/xx
Check your number(s) again & post them here & we'll tell you what you bought.
Incidentally, why did you buy it if you didn't know what is is ?
Andy
'69 911E-------->R
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 08-01-2003, 06:37 AM
fastspeed's Avatar
Porsche Crest 911 Engines Codes
Tanks Andy and Jim for your fast reply to my advice.
I will double check the ID number in the engine.
I bought the 911 engine with 901 trans.,to adapt in a 93 bus,
in a last of the case,probably i will have 130HP if is 2L.
Best Regards.
Old 08-01-2003, 02:48 PM
fastspeed's Avatar
911 Engines code
I checked the 911 engine code again and the number is the next;
901105111OR,please somebody know what 911 engine is this?
Old 08-04-2003, 03:36 PM
That's not the engine number - it's a casting number.
The serial number is stamped on the vertical surface & the type number can be found on the horizontal surface:
(Picture courtesy of Nick Moss)
Andy
'69 911E-------->R
Old 08-04-2003, 04:04 PM
fastspeed's Avatar
Thanks Andy,i will check again.
Fastspeed Mario.
911 Carrera Cabrio 88.
Old 08-04-2003, 04:14 PM
What can you guys tell me about the 3.0 I have in my 74-911? This is the number I found:
930.101.104.4R
Thanx
Old 08-04-2003, 11:28 PM
nick-moss's Avatar
Frostie
That is a casting number. Look again
Nick Moss - RGruppe #318
early911.co.uk
Old 08-05-2003, 01:23 AM
fastspeed's Avatar
I checked again and numbers are:901/02 7782 Horizontal Surface
and 961390 Vertical Surface.
Thanks for the asistence.and Nick Moss for the picture.
Fastspeed.Mario
Old 08-05-2003, 03:10 PM
Bandwidth AbUser
Mario, you threw me off with such an oldie. Here's what I think you have...
It's a 1967 911S engine, 2.0L, 9.8:1 conpression ratio, 160HP @ 6,600 rpm, 132 ft-lbs torque @ 5,200 rpm. Should be fun in your 93 bus.
Jim R.
Old 08-05-2003, 03:26 PM
That's a 1967 2.0S engine. Rated at 160bhp @ 6600rpm & 132ft.lbs torque @ 5200rpm.
Andy
'69 911E------>R
** Jim beat me to it !!
Andy
Old 08-05-2003, 03:30 PM
fastspeed's Avatar
Tanks,Jim Andy and Nick for the help,i will enjoy this engine.
Regards
Fastspeed Mario.
Old 08-05-2003, 03:40 PM
Pieta's Avatar
me 2 please?
Hi from South Africa.
Can you help me with this one?
63D3985
It is a RHD 911 and I think it is a 1978 .
serial number inside the bonnet: 7812175186080
Another one?
6372563 is installed in my sons 1977 LHD Targa?
Thanx a million.
Pieta
Old 01-02-2011, 12:11 PM
63D3985 is an '83 3.0SC engine - type no 930/10 - rated at 204 bhp @ 5900
6372563 is a '77 2.7 engine - type no 911/81 - rated @ 165 bhp @ 5800
Andy
Old 01-02-2011, 12:25 PM
Grady Clay's Avatar
This is what Pelican is all about – Venezuela, South Africa, UK, Canada, ‘Earth’ and even Wayne (our host) in SW LA all working together about Porsche. Good for everyone.
I can sit in my library in Colorado, offering sage advice and have almost as much fun as if I were racing Daytona. … well.
It turns out that fastspeed has a very desirable #961390 1967 911S engine type 901/02 that was built in early 1967. It falls in the range on 961141 to 962178 built from January ’67 through July ’67.
You should consider reuniting that engine with a (or THE) 911S it was built for.
The value of this engine can pay for a 911 3.2 Carrera engine and more. Far more suitable for your VW. There are several here in Colorado who can help.
Search this (and other) forums about this very desirable conversion. This is an opportunity to have something far better for your VW and reunite the 901/02 engine with it’s original chassis (or close).
Pieta, WELCOME, you will find a lot of help here.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 01-02-2011, 01:05 PM
Pieta's Avatar
Talking Bought my 911 SC because of this forum
Thanks a million guys!
Because of the info you gave me here, I could make a decission on what the car really was.
It was a 1983 911 SC with 993 body kit (fibreglass) on it.
I got the price down buy half mainly due to your info, plus the condition the bodywork was in.
I am very happy with the mechanicals.
...and it is Yellow (with a GT2 tail which has to go!)
Thanx again.
Old 01-25-2011, 11:39 AM
djpateman's Avatar
Interesting, the original thread was from 2003 (eight years old). My info is that the 67S engine is now in Australia.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 01-26-2011, 09:08 AM
Max007's Avatar
Hi my friends,
I'm new in this interesting forum.
I have a similar question as Fastspeed.
I have a '71 911 and I would like to restore it.
I'm not sure about her engine.
The seller told me it is a 2.2 but not the original one.
The numbers are 61008xx (the last 2 numbers are not readable)
Is there anybody who can tell me which kind of engine is?
Thank You in advance
Max007
Old 02-14-2011, 11:48 PM
