scedmonds's Avatar
SC A/C spitting black foam bits . . . ??
My '83 SC has been running perfectly, but a week ago the A/C (replaced a year ago with the rotary unit) began spitting tiny black foam pieces out thru the vents.
The first batch was a bit oily (white SCWDP t-shirt splotchy, but it washed out), but lately it's dry . . . tiny . . . bits of black foam.
I'm not a wrench, but I did check out the engine compartment -- nothing seems out of line -- I didn't see anything that would contribute to this problem (but it was a quick, cursory look).
I've done a search of the archives here and found zilch.
Has anyone experienced anything like this, heard of someone else's similar condition, and/or has an option about repair?
Cheers!
C.
S. Chris Edmonds
1983 911SC Targa SOLD
Sale Site with pix
Old 08-08-2003, 03:24 PM
Thats the seal that keeps the air in the system. It got old and is falling apart. It is likely from around the evaporator and/or the vents behind the dash.
Old 08-08-2003, 03:33 PM
david914's Avatar
Yeah, you're going to want to eventually pull the evaporator box out and clean and re-seal everything. As long as your A/C is still working OK and you don't mind the occasional piece of foam "shrapnel" coming out at you, I would leave it alone. To do it right, you need to have the system evacuated, pull, clean and re-seal the box, then have a vacuum pulled on the system then re-charged.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 08-08-2003, 04:05 PM
scedmonds's Avatar
Thanks, guys -- sounds like that's the problem. The A/C is cooling great -- I can certainly deal with the occasional naughty bit . . .
Cheers!
C.
S. Chris Edmonds
Sale Site with pix
Old 08-08-2003, 04:14 PM
