CA Smog check time....any tuning suggestions to help pass???
It's that time again. Time for a good ol' California smog check. Car is stock, an '83 SC......Already have done most minor servicing. IE oil/filter, fuel filter, clean and recharge KN air filter, Cap/rotor, and timing. Been 6,000 miles since last valve adjustment, plugs and the O2 sensor was replaced then, also.
Any tips as far as ways to help insure passing the CA smog check in an SC???? Thanks in advance!!!!
Mike 83 SC Last edited by MY83SC; 08-19-2003 at 03:16 AM.. |
Guess I must be on the right track.......
Mike 83 SC |
Passed with flying colors!
15MPH.. HC (PPM) Max=141....Meas=60 CO (%) Max=0.99.....Meas=0.24 NO(PPM) Max=1148....Meas=495 25MPH.. HC (PPM) Max= 113....Meas=69 CO (%) Max=0.79...Meas= 0.29 NO (PPM) Max=978....Meas=556 ...And I still need to do a valve adjustment and change the plugs.....Just glad I passed....Dreaded it!
Mike 83 SC |
Formerly bb80sc
Yeah, these cars are pretty amazing. I just passed.....with a gutted catalytic converter
Shhh, don't tell anyone. I was able to tune my CO down to .44 by leaning her out. Of course, it was all I could do to keep her idling. Before I started adjusting the mixture I had CO of 3.17!! The only part I failed on was the gas cap.....go figure.
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
