New Starting Problem
When I go to start the SC, it will fire and then die immediately. I go through this a few times before the engine stays running. Once is finally starts, it will go through a normal warmup (increased idle for a couple minutes) and then settle down. Any ideas? Could it be the WUR?
Jay Houghton
Marietta, GA
1981 911SC
1986 944 Turbo
Old 08-21-2003, 01:47 PM
Cool
I don't know much about the SC CIS..
how about the cold start valve and its wiring
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-21-2003, 09:54 PM
fogcity's Avatar
Needs a "tune up"?
1984 Carrera Coupe
Old 08-21-2003, 09:56 PM
Somewhere in the Midwest
MotoSook's Avatar
Yep! Sounds like a little CIS tweeking is in order.
After warm up...does it run rich? Lean?
Old 08-21-2003, 10:29 PM
I have already done a tune up about 4k ago. After the car starts and stays running everything is fine. The CO levels are right on that is why I am leaning towards the WUR. Any more thoughts???
Jay Houghton
Marietta, GA
1981 911SC
1986 944 Turbo
Old 08-22-2003, 08:10 AM
Senior Member
Doug Zielke's Avatar
As mentioned here *many* times before, you can't do very much CIS troubleshooting, without a pressure test kit.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 08-22-2003, 08:33 AM
