New Starting Problem
When I go to start the SC, it will fire and then die immediately. I go through this a few times before the engine stays running. Once is finally starts, it will go through a normal warmup (increased idle for a couple minutes) and then settle down. Any ideas? Could it be the WUR?
Jay Houghton Marietta, GA 1981 911SC 1986 944 Turbo |
I don't know much about the SC CIS..
how about the cold start valve and its wiring
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Needs a "tune up"?
1984 Carrera Coupe |
Somewhere in the Midwest
Yep! Sounds like a little CIS tweeking is in order.
After warm up...does it run rich? Lean? |
I have already done a tune up about 4k ago. After the car starts and stays running everything is fine. The CO levels are right on that is why I am leaning towards the WUR. Any more thoughts???
Senior Member
As mentioned here *many* times before, you can't do very much CIS troubleshooting, without a pressure test kit.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
