Now that I have your attention
![]() As some of you might have read before, I'm going to attempt my first AX on Sunday. But, I need to put a little more negative camber in my d-side rear wheel tomorrow (it rubs a little, under hard acceleration in a right turn). I have done a search and have a TON of info, but I still have Two questions. 1. Does anybody know the size of the allen bolts that control the camber and toe? I only have up to 10mm in allen wrenches, and the 10 is too small. I need to buy one tonight! 2. Does anybody know the torque setting for those two bolts?
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please ![]() Chad aka "Chili" 1974 Base coupe in Carrera outfit. No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.) My car http://www.pelicanparts.com/gallery/CHILI 1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras. |
Bandwidth AbUser
12mm - bought it at Sears. I don't know the torque offhand. Will need to look it up.
Jim R. |
Thanks Jim! I was at Sears last night and took a guess at the size. Bought a 10mm in a socket (not sure what they're called). I didn't see a 12mm, though. I would have bought it just for good measure. I'm going to take the 10mm back ($6) and ask if they have a 12mm since I would like to torque it to correct specs. Otherwise, I would just buy a 12mm normal wrench.
Anyone on the torque setting? Anyone?
Bandwidth AbUser
On early cars, the torque specs are approx 36 ft-lbs for the toe adjustment, and 43 ft-lbs for the camber adjustment.
Jim R. |
JOT MON ABBR OTH
It does matter, only the nice ones will tell you doesn't. Oh, uhm, keep the 10mm Allen as you will need it in the future!! When I was stuck and didn't have a good allen socket I took a standard allen wrench and cut it in order to create a makeshift tool. It worked very well and the little bit stays in my tool box...
David '83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)'15 F250 Gas (Her Baby) '95 993 (sold )I don't take scalps. I'm civilized like white man now, I shoot man in back. |
Might i ask where this A/X is this Sunday? i just checked the OCR callender and they don't have one scheduled? tia.
It's at California Speedway. Here's a link, just check "Coming Events"
http://www.pcasdr.org/home/index.html
