Idle adjust... which way?
Before I start fiddling with my engine, which way do you turn the large idle adjust screw to increase the idle slightly? Clockwise or anticlockwise? ['77 CIS 2.7 liter]
Thanks, -MAS
77 911S Targa (current car) 87 924S (my previous car) |
SCWDP- Shock and Awe Dept
Clockwise to decrease idle, Counter(Anti) Clockwise to increase.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
You'll know as soon as you start turning it.
Joe |
"You'll know as soon as you start turning it. "
Unfortunately it's a bit more complicated than that, which is why I only asked the one question. Here's my problem: That's what I thought when I tried to adjust the idle a couple of months ago. However, it seems that my idle is often slowly goes down from about 1000 rpm to about 200... and then to stall after a minute or two (sometimes faster). It's at its worst when the car has been running at a higher rpm. There seems to be little difference in the idle no matter which way I rotate the screw. Any other ideas where the problem may be? Thanks ![]() -MAS
Wow, that is a bit more complicated! Have you done anything recently that may have caused a problem? Has it always been that way?
Joe |
The idle has always been a bit of a problem. The local Porsche dealer has a few mechanics that know older Porsches really well... so I think I'm going to ante up the $$$ for a full tune up from the dealer. I'll leave it to them to replace any leaking/worn hoses, etc.
-MAS
Best idea I've heard yet.
Good Luck, Joe |
