IAN IAN is offline
Help, redish fluid leaking....
I just noticed a new puddle under the front of my 72 911 T.
It appears to be a redish oily fluid that is leaking from a bolt that comes out of the rear of the gas tank.
I'm a bit confused because I can't tell what this stuff is. It's not gasoline.
Anybody have any thougths?
The master cylinder is not leaking any fluid at all.
thanks,
ian
Old 08-31-2003, 09:51 PM
I haven't been under the front of my car for a while, but if it isn't rusty gas! then it has to be brake fluid.
Take off the large plate under the front of the car (four bolts), look for a wire going to a sensor almost in the middle of the car, this could be your leak.
Jeff
'72 911T gone
'85 TVR
Old 08-31-2003, 10:30 PM
