Help, redish fluid leaking....
I just noticed a new puddle under the front of my 72 911 T.
It appears to be a redish oily fluid that is leaking from a bolt that comes out of the rear of the gas tank. I'm a bit confused because I can't tell what this stuff is. It's not gasoline. Anybody have any thougths? The master cylinder is not leaking any fluid at all. thanks, ian |
I haven't been under the front of my car for a while, but if it isn't rusty gas! then it has to be brake fluid.
Take off the large plate under the front of the car (four bolts), look for a wire going to a sensor almost in the middle of the car, this could be your leak. Jeff
'72 911T gone '85 TVR |
