I would rather be driving
jpnovak's Avatar
intake stud spacing
I am tearing down the top of the engine to a long clock for cleaning. What is the intake stud spacing for a 78 3.0. I need to make some intake covers to keep trash out.
jamie
Old 09-12-2003, 07:00 AM
Chain fence eating turbo
jamie
You ever find this out?
I wanted to verify my measurements with others before I pull the trigger on machining my parts.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 01-09-2018, 10:27 AM
Painters tape not a long term solution?
You have vernier calipers or a ruler? To determine the center-to-center space, measure the outer dimension from stud to stud, then subtract the OD of one stud from that measurement......
...... or take an intake gasket, trace it on some paper, then measure those dimensions. The cover you fabricate along with used gaskets and gasket sealer should do the job.
Sherwood
Old 01-09-2018, 10:49 AM
Intake runners studs spacing.......
jamie
Jamie,
I got 66 mm +/- 0.5 (center to center) from my 78 SC engines.
Tony
Old 01-09-2018, 10:58 AM
911T '72
DeRRis's Avatar
Yes 66 mm (79mm -13mm = 66mm), measured on a large port 1978 3.0 SC engine
Dennis
Good drivers have dead flies on the side windows. (Walter Röhrl)
Old 01-09-2018, 11:31 AM
I got 2.597" from my crappy Harbor Freight calipers that fluctuate 0.005".
Looks like I was only 0.001" from being accurate.
Not too bad!
Old 01-09-2018, 12:16 PM
If you guys didn't see, Jamie asked this over 14 years ago.....
Old 01-09-2018, 12:21 PM
911T '72
DeRRis's Avatar
And you did again today
Dennis
Old 01-09-2018, 12:26 PM
Yep. It came up in a Google search. Beings it was 14 years old, I had to post to it.
Old 01-10-2018, 06:57 AM
14-year old post.........
Tippy,
You are the one responsible for bringing this very old post back to LIFE.
Tony
Old 01-10-2018, 07:12 AM
