Kolibri
blackbird225's Avatar
Porsche Crest 911T Engine to S specs?
What would it take to get the same performance numbers of an 1970 S in a 1970 T? Is it just MFI or a host of tweaks? I know that this has probably been tossed around before, but I thought I might dig it out again.
TIA,
michael
Old 09-14-2003, 06:58 AM
A S has compared to a T the following differences:
forged pistons, giving higher compression, biral barrels
nitrated conrods
higher lift, more duration camshaft.
Heads with bigger ports and valves
a counterweighted crankshaft which copes better with high rpm's (at which the S has its max power)
You would at least need pistons, cams, and heads if you would stick with carbs. A MFI setup would offer another 10hp in the same setup.
In all no simple tweaks. If you are considering to go this way you could also opt for a short stroke 2.5
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 09-14-2003, 07:24 AM
exc911ence's Avatar
How about the T and the E spec engines. Would this be a simpler upgrade?
1979 911SC "Frankencab"
Dave
Old 09-14-2003, 08:21 AM
Randy Webb's Avatar
Worse than that -- the T's crank is not counterwt'd so it may not last of reel well at high revs. PAG used a base T engine for some races but I dunno how often they had to rebuild it.
Unless you find a new crank and a lot of other items, you should think about swapping in a whole new engine. What's your goal? A built 2.7L is a great project and can be very fast. My '73 T had a stock 2.7L when I bought it, and I am putting in a hotrodded 3.2. The sky is the limit -- or at least a hotrod 3.8 is the limit. That will be enough to kill the unwary in short order.
Take a look at BA's book and also the "best engines" chart in Wayne's book.
Old 09-14-2003, 10:35 AM
Crusty Conservative
silverc4s's Avatar
I think there are a few racers on this board the use or have used the non-counterweighted crank with good results...don't just throw it in the trash.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 09-14-2003, 11:36 AM
The crank is strong enough, the problem is a non counterweighted crank puts more stress on the main bearings. Apparantly Porsche decided that this was permissable for the lower reving T but not for the E and S. For the 2.4 all cranks are counterweighted.
Racers like this crank as it is lighter, and therefore revs easier (just like a lightened flywheel), the higher wear on the bearings is not such an issue in these applications as these engines are probably opened more often.
Peter
'13 981S
'73 911T
Old 09-14-2003, 11:58 AM
