Randy Webb's Avatar
unknown relay
Anybody know what this relay does -- I found the cover and am putting it back on. I wonder if this is important?
I'm pretty sure the car is 1 1973.5 -- so it must have come stock with CIS. Could that be what this relay does?
Old 09-21-2003, 11:55 PM
In the 1973.5 T's the CIS related relay is located on the electrical chassis on the driver's side of the engine compartment. Given it's location (up front in the luggage compartment near the fuse panel) the relay in the posted image appears to be the horn relay. Cheers, Jim
Old 09-22-2003, 04:09 AM
Randy Webb's Avatar
Thnaks -- is t supposed to just hang there? Or is there a holder like in the later cars?
Old 09-22-2003, 09:45 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
looks like the horn relay or another one of those relays by the fuse panel. it's the standard relay size I belive.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 09-22-2003, 09:47 AM
No, see that hole above and behind the relay and relay base? A rubber "dart" molded into the relay base plugs into that hole and holds the base and relay secure. That relay warrants replacing if you care about your horns working. Jim
Old 09-22-2003, 11:53 AM
Randy Webb's Avatar
Thx. Jim. Actually I don't really care about the horn -- engine first, then tires... horn later (since it still works right now).
Old 09-22-2003, 04:48 PM
